The easiest method is to replace the old movement with a new movement of the same calibre (and from the same manufacturer of course).
The easiest way to find out the movement calibre is to look for stamped marks under the balance wheel .. unfortunately not all manufacturers put there marks there and the traditional way to ID a movement is to remove the dial and compare the setting works against sketches.
