Goal: $300, Received: $225.00 (75%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 4001 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 6 of 6
    v-regulator
    Guest
    Default clock running too fast
    I have a French crystal clock which I bought
    some 10 months ago.It is at least 80 years old.
    The suspension spring was changed because the
    pendulum was wobbly.
    The clock has since been gaining time - some
    5 mins in 3 days.
    Despite adjusting the pendulum length almost to
    the maximum it continues to run fast.
    The clock is otherwise ok.
    Can anyboby help?
    v-regulator
    Guest
    Default clock running too fast (By: v-regulator)
    5 mins in 3 days.
    Can anyboby help?
    Peter G Mitchell
    Guest
    Hi,
    Is the suspension spring the same length as the old one? is it the same strength (thickness) if the suspension spring is too thick it can "wag" the pendulum, this prevents a good amplitude on the pendulum this can cause the clock to gain, some years ago I had the situation on a French clock whereby a suspension was too thin, thus the amplitude excessive and the pendulum was bouncing off the banking pins in the back plate this also caused the clock to gain.
    Pete
    Registered user.
    Jan 2005
    Birmingham, UK
    837
    We need more information and a picture would accelerate things greatly.
    Chances are like Peter says the suspension could be a bit too thin or long for the clock or the bob/weight(s) is not moving when you turn the adjuster.
    Registered user. Mike Phelan's Avatar
    Dec 2003
    West Yorkshire, England
    9,823
    VR says it is running fast
    Mike - banned member of the throwaway society. :o
  6. #6
    v-regulator
    Guest
    Hello Peter , oldticker and Mike
    Many thanks for the pointers.
    My clock repair man changed it for me and since then the clock has been gaining time.
    I will get him to remedy this.
  1. French clock runs too fast
    By George Schultz in forum Clock Repair
    Last Post: 10-21-2006, 04:41 AM
  2. Small black forest alarm clock runs too fast.
    By 107WestStreet in forum Clock Repair
    Last Post: 03-29-2006, 07:04 AM
  3. Clock running too fast
    By Kevin M in forum Clock Repair
    Last Post: 02-11-2006, 08:07 AM
  4. 400 Day Clock Running Too Fast
    By timelyrestorations in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 08-29-2004, 03:50 AM
  5. Ships Clock Runs Too Fast
    By proconsul in forum Clock Repair
    Last Post: 10-04-2003, 12:16 PM
Members who have read this thread: 2
