Results 1 to 6 of 6
Thread: I'm going cuckoo
    Aug 2003
    Towanda, PA
    244
    usa  us pennsylvania
    NAWCC
    Default I'm going cuckoo
    I enjoy working with cuckoo clocks, until now. I've had in for repair a Schatz 8 day cuckoo. Repairs made, it ran in the shop for a month without any problem. I made a special delivery to the owner. Placed it on the wall, set everything up properly and started the pendulum. Went back to my home shop. Next day received a call the clock was not working. Because of medical reasons I returned to look at the clock. Could not get it to work. Back to the shop with the cuckoo clock. Check everything out and it has run for another month. Yesterday I redelivered the clock. Back on the wall, started it running. Decided to stay awhile. It was in beat, but it stopped about 45 minutes later. Restarted, it keeps stopping within 5 minutes. Brought it back and it has been running in the shop since yesterday. I don't know if the clock likes me, the house is haunted or I'm missing something. Open for ideas before I go cuckooooooo.
    Ed Schmitt
    Shadows of Times Past
    Nov 2002
    28,736
    canada  ca ontario
    NAWCC
    Default Re: I'm going cuckoo
    Ed, check that the cuckoo is flush to his wall, and that the wall is reasonably plumb. If he has a long enough screw that the top of the case leans forward, this will stop the clock, if the pendulum or leader is rubbing on anything in the case when it's out of plumb.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Oct 2010
    4,066
    Hi
    As well as any angle of the mounting, check for
    drafts. Even a small amount of air flow from a heater
    vent can stop an 8 day clock.
    Tinker dwight
    Oct 2005
    19,608
    usa  us iowa
    NAWCC
    Also check to see if it stops during the strike. Could be the pendulum is hitting the lift wires if it's leaning a bit back further than your test stand.
    Quote Originally Posted by Tinker Dwight View Post
    Hi
    Tinker dwight
    Yes ...
    And most 8-day cuckoos are allergic to ceiling fans, even if they are 10 feet away.
  6. #6
    Aug 2003
    Towanda, PA
    244
    usa  us pennsylvania
    NAWCC
    Thanks guys, I'll have to check the heat and air flow when I take it back. I'm pretty sure the lift wires are ok. I'll let you know. Thanks for your input and ideas.
    Ed
  1. "Going Cuckoo" for the Message Board!
    By soaringjoy in forum Your Newest Clock Acquisition
    Last Post: 09-21-2012, 01:35 PM
  2. Going Cuckoo!!
    By Mary Ellen in forum Clock Repair
    Last Post: 01-31-2010, 04:19 PM
  3. I'm going CUCKOO
    By Ed Schmitt in forum Clock Repair
    Last Post: 04-21-2008, 09:30 AM
  4. Cuckoo reluctant to go home
    By TonyR in forum Clock Repair
    Last Post: 08-12-2005, 04:31 AM
  5. cuckoo clock--here we go again
    By RL in forum Clock Repair
    Last Post: 04-16-2005, 12:54 AM
