03-04-2012, 09:44 PM #1Registered user.
- Join Date
- Sep 2011
- Location
- Missouri
- Posts
- 42
1790 tall clock with wood gears-straford, connecticut
Any id on this clock that is in our family?
03-05-2012, 07:54 AM #2
Re: 1790 tall clock with wood gears-straford, connecticut
Any clues from the papers attached to the inside of the door?
How about a few pictures of the movement?
03-05-2012, 11:15 AM #3Registered user.
- Join Date
- Sep 2011
- Location
- Missouri
- Posts
- 42
Yes...that would be nice but it is not in my home but rather in another state, currently. I could kindly ask my family member to take extra pictures.
Any clues from the pics available?
I noticed that the key holes are white rather than dark...as if not functioning, but that does not make sense since I am told it is still working properly and keeps time. (I may have to ask about that.)
Do you think there is a missing brass or wood pediment in the center?
From the Straford Connecticut location, do you think that puts it in the hands of any particular maker??
Geof W
03-05-2012, 11:26 AM #4Registered user.
- Join Date
- Aug 2009
- Posts
- 320
Is that Staford, or stratford?
The ticking of a clock, the heartbeat of time
03-05-2012, 12:22 PM #5Registered user.
- Join Date
- Sep 2011
- Location
- Missouri
- Posts
- 42
03-05-2012, 12:53 PM #6
I may be able to tell you the maker, but not without good, clear, well lit pictures of the movement, including one of the back plate, one of the time side, and one of the strike side. Movement characteristics are often the only way to determine a maker, short of a signed dial. This is a 30 hour wood pull up movement, and the false winding holes are a common decorative conceit- almost all wood dials of this era feature them, and they are original. Your movement was probably made circa 1810-30.
12-12-2012, 06:54 AM #7Registered user.
- Join Date
- Sep 2011
- Location
- Missouri
- Posts
- 42
12-12-2012, 09:50 AM #8
From what I can see, it looks like a Mark Leavenworth product, but it's hard to tell for sure without good pictures.
12-13-2012, 06:21 AM #9Registered user.
- Join Date
- Sep 2011
- Location
- Missouri
- Posts
- 42
Mark Leavenworth...is that a modern reproduction? or was he an early maker? Sorry not up on the subject
12-13-2012, 06:55 PM #10
Sounds like to you need to begin building your library. a good place to stare is Spittlers' and Bailey, Clockmakers & Watchmakers of America, available from NAWCC or the American Clcok & Watch museum, as well as on eBay.
Mark Leavenworth was the nephew of Colonel William Leavenworth, and was active until around 1834, though he probably stopped producing tall case movements well prior to that date.
The book is also available directly from Tom Spittler, and he will of course autograph it. Please send me a P.M. if you'd like his contact information.Last edited by Peter A. Nunes; 12-16-2012 at 07:14 PM.
YOU ALL HOOKED ME :) A JEROMEs & DARROW with wood gears is my new find.
By BDARD in forum Wood Movement ClocksReplies: 17Last Post: 01-25-2011, 07:31 PM -
Best woods for wood gear clock making
By FreWJensen in forum Wood Movement ClocksReplies: 22Last Post: 01-31-2007, 12:18 PM -
Kienzle pendulum clock with plastic pendulum gears
By techy6131 in forum 400-Day, Atmos and other Torsion ClocksReplies: 7Last Post: 06-11-2006, 11:59 PM -
1860's Wooden gear tall clock
By ladutka in forum Clock RepairReplies: 2Last Post: 12-01-2003, 11:14 PM -
Tall clock with steel works
By LaBounty in forum Clocks General.Replies: 2Last Post: 03-10-2003, 04:51 AM
About the Message Board
This will be an ongoing blog to chronicle the development and use of the NAWCC Message Board. Please reply with your thoughts as you feel appropriate. June 2013 marks the deployment of the last edition of vBulletin V4. We will continue using this version of the software until vBulletin V5 has been widely deployed and had a thorough shakedown. That may take as much as 3 years. In order to freshen the look of the message board, several changes have been made in this deployment. The most...
05-31-2013, 04:23 PM in Tom McIntyre
