Goal: $300, Received: $280.00 (94%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 1788 days ago. If your post is not directly related to this discussion please consider making a new thread.
    Feb 2012
    Manitoba, Canada
    121
    Default Movement kits & suppliers
    I am looking for a grandfather size movement kit with Westminster chimes that includes all the working parts (movement, weights, pendulum, moon dial, hands, etc.) for a new custom clock and looking for a seller with good prices and reputation. It doesn't have to be new (the movement, not the seller ). Price IS important.
    I have an older Urgos movement but by the time I add all the other bits to make a working timepiece the cost is on par with a new movement.
    What do ya'll recommend?
    Dianne
    38,596
    Default Re: Movement kits & suppliers (RE: DianneB)
    Hi, Dianne. I don't think you will find anything particularly cheap, but Murray Clock Craft sells kits for GF clocks. www.murrayclock.com
    Have you considered using an older (read, better quality) movement?
    Patience on ebay might reward you with what you need, as long as you know what you're doing, and what you need.
    Feb 2012
    Manitoba, Canada
    121
    Default Re: Movement kits & suppliers (RE: harold bain)
    I HAVE a movement - it is just that all the other bits and ends drive the cost up into the same range as "movement kits"
    California
    1,461
    I think that what Harold is saying is that the new movement won't be as good as an older movement (which you have) so if the price is the same, go with the older movement.
    38,596
    Default Re: Movement kits & suppliers (RE: Rob P.)
    Quote Originally Posted by Rob P. View Post
    Actually, what I was thinking is that a movement from pre WW11 has much better quality than anything produced in the 1970's and beyond, but not knowing the vintage of Dianne's Urgos, I'm only assuming it's a newer one, post WW11.
    Dianne, I often see packages like you are looking for at NAWCC chapter marts and regionals for pretty reasonable prices.
    Feb 2012
    Manitoba, Canada
    121
    Thanks guys - I understand what you mean about quality.
    The movement I have coming is a UW 32/3 presumed to be from the 1960s.
  1. European suppliers of parts/partial movements
    By wilsonpaule in forum European & Other Pocket Watches
    Last Post: 11-29-2011, 05:31 PM
  2. need supplier of quartz speacial movement
    By wingardclocks in forum Clock Repair
    Last Post: 12-12-2007, 02:06 PM
  3. Supplier for Old & Antique Movements?
    By Tom Englund in forum Clock Repair
    Last Post: 12-12-2007, 09:21 AM
  4. Explaining movement
    By smurf in forum Clocks General.
    Last Post: 10-31-2005, 10:46 PM
  5. Lenzkirch parts supplier
    By RBW in forum Clocks General.
    Last Post: 09-23-2002, 05:30 AM
