Results 1 to 5 of 5
Thread: Trying to find info on movement identification
    Jun 2010
    North Stonington, Ct.
    112
    usa  us connecticut
    NAWCC
    Default Trying to find info on movement identification
    Hi I'm working on a "Seth Thomas" triple chime grandfather and would like to learn how to read the movement codes.
    I found that Talley owned the company from 1969 -1988. On the plate it says
    MADE IN USA FOR
    SETH THOMAS
    A TALLEY INDUSTRIES CO
    NORCROSS , GA . USA
    8506
    A 415 - 013
    Thanks for any help Earl
    Nov 2002
    28,736
    canada  ca ontario
    NAWCC
    Default Re: Trying to find info on movement identification
    Hi, Earl. The movement was made by Hermle, and the numbers indicate a Hermle # 1161-853BS/94.
    Made in June, 1985.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Jun 2010
    112
    usa  us connecticut
    NAWCC
    Thanks Harold Anyway I can learn to how to identify the codes ?
    Nov 2002
    28,736
    canada  ca ontario
    NAWCC
    Earl, I have a sheet that Butterworth Clocks sent me out many years ago (2004), with all the conversion numbers. Perhaps if you contact them, they might still have this available.
    If you repair clocks on a regular basis, this sheet helps you to know if there is a replacement movement available in case you would prefer to do a direct replacement rather than overhaul the existing movement.
    Jun 2010
    112
    usa  us connecticut
    NAWCC
    Thanks Harold I've already rebuilt the movement and it's running great. I will try and find a copy. I did find the Hermle Service Manual lots of good info.
    Earl
  1. Trying to find info on this clock
    By rbaconii in forum Clocks General.
    Last Post: 07-04-2011, 01:01 AM
  2. Trying to find info and value on Varix Watch
    By SteveT in forum Wrist Watches
    Last Post: 07-07-2010, 02:18 PM
  3. Unable to find info on Pocket watch
    By Jhere66061 in forum European & Other Pocket Watches
    Last Post: 07-06-2008, 08:37 PM
  4. trying to get info on an old clock (I think)
    By linda payne in forum Clocks General.
    Last Post: 12-14-2006, 11:26 AM
  5. Trying to find info on the EN Welch Garcia Kitchen Clock
    By john brendel in forum Clocks General.
    Last Post: 01-02-2003, 10:57 PM
