Goal: $300, Received: $215.00 (72%) Contribute Now
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Dec 2011
    Brockville, On Canada
    5,662
    Default Junghans Quartz 85 movement W085/00675
    Hi Folks. Now before you tell me to forget it, I would still like to get this clock going for a friend. It has some sort of sentimental value. They asked me to fix this clock and showed me a small white part that "fell out". This is the V shaped piece - one end goes over an eccentric on a gear the other end has a short rack which drives the face gear, which in turn drives the pendulum. When I opened the cover for the movement, most of the gears were loose inside. It appears to me that there is perhaps an intermediate plate that supports a couple of gears and the V shaped piece.....but alas it isn't there. If ever there was a place for tamperproof screws, this is it. The owner took the screws out to change the battery a year ago and all the guts fell out.
    Does anyone have pictures of the inside of one of these movements? And I guess alternatively do they make a direct replacement for this movement? This pendulum doesn't have a suspension spring. The bottom of the pendulum is supported by a pivot and there is a pinion on the top of the pendulum shaft.
    Thank you, David
    Dec 2011
    5,662
    Default Re: Junghans Quartz 85 movement W085/00675 (By: David S)
    Ok I kept searching and found a picture of the inside in one of the previous posts. I am good now. I should have done a more thorough search before.
    DAvid
    Where is the picture of the inside. terryval
    Dec 2011
    5,662
    Default Re: Junghans Quartz 85 movement W085/00675 (By: terryval)
    Quote Originally Posted by terryval View Post
    Is this what you need?
Name:	Quartz 85 movement inside.jpg
    David S
    Hello
    This movement is made by HALLER.
    There are hundreds of different clocks with this movement.
    Haller once praised this movement in his patent as a major innovation,
    because it needs no suspension spring.
    Unfortunately, it is a poor movement.
    Sometimes it works, sometimes it does not work. (The same clock!!)
    And believe it or not, it stops because the axis of the stepper motor
    gets dirty.
    I find my replacement movements for little money at the flea market.
  6. #6
    Registered user. MartinM's Avatar
    Jun 2011
    El Dorado, CA
    2,286
    Default Re: Junghans Quartz 85 movement W085/00675 (By: DieteR)
    Many of these style movements included the facility to use a seconds hand; but, in place of the seconds hand, a decorative button is used. Many times, the clock is stopping because the button is pushed onto its shaft, a bit too far. If there is no seconds hand, the minute hand can, on some clocks, hinder the seconds shaft and cause the same problem.
    The only other causes of stopping I've seen on these are severe corrosion (Usually related to the button issue, above and sometimes, terminal) or dirt/lint in the pendulum pivot or ball bearing.
    Living life at eight beats per minute.
  7. #7
    Default Re: Junghans Quartz 85 movement W085/00675 (By: MartinM)
    David,
    These were made in large numbers but there are no new replacements available AFAIK. In my experience these work very well. I like the feature that uses the flexibility of the long wish-bone to protect the mechanism from damage. A gross over-swing of the pendulum will just make the pinion chatter on the end of the rack. When the pendulum almost stops the mechanism will go back into action as if nothing unusual happened!
    As already mentioned, these often show up in a plastic bag where someone took out the screws to change the battery ...
  8. #8
    Default Re: Junghans Quartz 85 movement W085/00675 (By: Willie X)
    Try Loricron in Asheville, NC. They have a replacement unit for these. http://www.loricron.com/
  9. #9
    Dec 2011
    5,662
    Default Re: Junghans Quartz 85 movement W085/00675 (By: David B Pendley)
    Hold on guys. This is an old post, that just came alive again when terryval in post #3 asked for a picture, which I provided. I actually repaired this movement. Some one had opened the gear compartment instead of the battery compartment and all the gears and wishbone fell out. When they brought it to me, it was missing the plate that holds the gears and wishbone. I had to make a new plate.
    David S
  10. #10
    Hi Guys,
    I'm a newbie and trying to learn how to fix these little clock motors. My wife won't let me throw away the clock (sentimental value). Thank you for the picture on this thread, it helped immensely. I took lots more shots just to be sure to put it back together again. I don't see any problem with any of the gears. I got the motor to start running by pulling on the armature. It wouldn't pull out. DieteR mentioned that the axis of the stepper motor gets dirty. Do I need to pull out the motor? I tried prying a little but the motor platform didn't appear to want to come out and I thought better to ask, than break it.
    With all the gears out, I can watch the motor stop stepping intermittently. It has been running for 20 minutes fully assembled, but I'm confident it will decide to stop. I'm running it without the pendulum What is wrong? Is there any hope for the clock?
    Thanks for your help. Please feel free to direct me to another thread that could solve my problem. I sure hope you have the ah-ha moment for me!
    Larry
  11. #11
    Default Re: Junghans Quartz 85 movement W085/00675 (By: ltelle)
    By the way Lorichron is out of business. I had to order parts direct from Haller in Germany. Good Luck!
  12. #12
    Dave thanks for your reply. I searched all over for Haller of Germany and haven't found any hits. Do you have a address or link?
    In the process of searching, I ran across the following thread on this site (http://mb.nawcc.org/showthread.php?7...ry-clock/page2).
    It describes the removal of the armature of the motor and cleaning. Do you think it will work?
  13. #13
    Registered User KurtinSA's Avatar
    Nov 2014
    San Antonio, TX
    1,555
    Should this be moved to the electric forum area?
    Kurt
  14. #14
    Default Re: Junghans Quartz 85 movement W085/00675 (By: KurtinSA)
    Quote Originally Posted by KurtinSA View Post
    Kurt
    Hi Kurt,
    I don't how to do that and didn't realize there is someplace else to be. Please give me some guidance.
    Larry
  15. #15
    Nov 2014
    San Antonio, TX
    1,555
    Larry -
    One of the moderators would have to do it.
    Kurt
  1. Replacement for Quartz 85..W085/00675 movement
    By David S in forum Electric Horology
    Last Post: 02-12-2012, 12:06 PM
  2. need supplier of quartz speacial movement
    By wingardclocks in forum Clock Repair
    Last Post: 12-12-2007, 01:06 PM
  3. Hamilton Quartz 955 Movement
    By harold in forum Wrist Watches
    Last Post: 10-19-2006, 04:01 AM
  4. Realistic sounding quartz chimining movements
    By timepast in forum Clock Repair
    Last Post: 08-14-2006, 07:07 AM
  5. Quartz cuckoo movement
    By BIG D in forum Clock Repair
    Last Post: 01-05-2005, 05:20 AM
