Goal amount for this month: 300 USD, Received: 220.00 USD (73%) Contribute Now
Donate whatever you can or Join the 16,000 other NAWCC members for only $72 (plus $10 for hard copy publications). Check it out here.
NOTICE Notice: This is an old thread. The last post was 500 days ago. If your post is not directly related to this discussion please consider making a new thread.
    Oct 2011
    Hudson, Quebec
    226
    Default Hamilton 912 with attractive dust cover - my 2nd Hamilton
    Came across a Hamilton that really caught my eye the other day. I couldn't leave it there due to the dust cover alone.
    It is a 912 , serial # 3239950, so it is not that old a watch, probably early 40s. Dial is a nice Art Deco style, outside of the case is in good shape, crystal is fine, and the movement runs great.
    What I really like is the Hamitlon name and Lancaster Pa engraved into the back of the dust cover. Is this something they did often? I have not seen many Hamiltons with this on them.
    Attached Thumbnails Attached Thumbnails ham 912 1.jpg   ham 912 2.jpg   ham 912 3.jpg   ham 912 4.jpg
    Registered User doug sinclair's Avatar
    Calgary, Alberta
    10,208
    Default Re: Hamilton 912 with attractive dust cover - my 2nd Hamilton
Name:	902 cuvette.jpg
ID:	119376I ran into a grade 902, 12-size, several years ago. The case was white gold filled. I took a picture of the cuvette because I too was impressed.
    Moderator Jim Haney's Avatar
    Sep 2002
    Decatur, TN.
    2,487
    Quote Originally Posted by wilsonpaule View Post
    wilsonpaule,
    This was quite normal for 12s Hamiltons. I believe it was done with acid etching.?
    Jim Haney
    Jan 2009
    So. Calif.
    2,324
    The Hamilton grade 912 was introduced in 1923 and continued in production until 1936. Total production for grade 912 was 260,900, which was by far the largest total produced of any "12-size" Hamilton grade. Your watch, ser. no. 3239950, is older than you think. It was made c.1924-25.
    BTW, I put "12-size" in quotes because Hamilton "12-size" watches were not standard 12-size and did not fit standard 12-size cases. The earliest ones were slightly larger than standard 12-size and the later ones were slightly smaller than standard 12-size, and all required special cases.
    Starting in 1936, Hamilton introduced an all-new line of 10-size watches which incorporated many technological advances, and which replaced the remaining "12-size" grades in the Hamilton lineup.
    Larry Treiman
  1. Help with my new Hamilton please
    By bujak in forum American Pocket Watches
    Last Post: 07-25-2012, 02:03 AM
  2. Replies: 4
    Last Post: 07-18-2012, 02:55 AM
  3. Haman dust cover on my 992.
    By LarFure in forum American Pocket Watches
    Last Post: 01-20-2006, 07:06 AM
  4. Hamilton 992 with bold silvered dial
    By ckeithjohnson in forum American Pocket Watches
    Last Post: 09-14-2005, 10:38 AM
  5. Pulley Dust Covers
    By Bruce Barnes in forum Clocks General.
    Last Post: 09-06-2005, 08:32 AM
