NOTICE Notice: This is an old thread. The last post was 1948 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 7 of 7
    Default Linden (W.Germany) 8 day mantel clock... worth repairing?
    Have an old mantel clock from my father in-law who passed this last year. My husband says it's worth fixing because it's from W. Germany. Spring mechanism doesn't work anymore.... Here's what's on the inside chime mechanism: 71 - Cuckoo Clock Manuf Co., Inc.TW0121JEWELS Made in West Germany unadjusted 1050-020 --- Any ideas --- where to get fixed, etc. We live in Chesapeake, VA 23322 Thank you!! Jackie
    Default Re: Linden (W.Germany) 8 day mantel clock... worth repairing? (By: Jackie)
    Sure, if you like it repair it and put it back in operation.
    Keep the 70s alive! :o
    Default Re: Linden (W.Germany) 8 day mantel clock... worth repairing? (By: Willie X)
    Where do I even begin to find a decent clock repair company? Thanks for encouraging us to get it fixed --- that's really what my husband wants to do!
    Apr 2002
    20,011
    Blog Entries
    Jackie there should be some NAWCC chapters in Virginia, i would contact them and go from there.
    Default Re: Linden (W.Germany) 8 day mantel clock... worth repairing? (By: Kevin W.)
    This is yet another Hermle movement. If it proves impossible to repair, you can probably find a new movement that is the same.
    "A good gong sells the clock!" - Justin A. Olson
  6. #6
    Registered User soaringjoy's Avatar
    Feb 2009
    7,240
    Default Re: Linden (W.Germany) 8 day mantel clock... worth repairing? (By: chimeclockfan)
    Jackie, first of all, welcome to the NAWCC Message Board.
    Maybe someone from the VA area will drop in and give you advice, where you
    can a repairer.
    If not, you can locate and contact your regional or local NAWCC Chapter right
    here - and they should surely know:
    http://mb.nawcc.org/showthread.php?8...s-in-your-area
    Jurgen
    Jurgen "tempus nostrum"
  7. #7
    The age on this movement, usually pays to replace it with the same movement that is being made today, and better quality. It is normally cheaper to change than repair, and it's completely new. I wouldn't ever suggest you change a movement out of an antique, but this isn't one.
    Larry Pearson, FNAWCC* #35863
  1. Kienzle Mantel Clock Dating & Repair Tips
    By Andysan in forum Clocks General.
    Last Post: 02-28-2012, 06:20 AM
  2. schatz & sohne 8 day mantel clock
    By bob asbra in forum Clock Repair
    Last Post: 11-11-2011, 04:41 PM
  3. session 8 day mantel clock id & year
    By appleheadq in forum Clocks General.
    Last Post: 04-19-2011, 01:35 PM
  4. Seth Thomas 8 day Westminster clock - worth?
    By xbassman in forum Clocks General.
    Last Post: 08-08-2009, 12:48 PM
  5. Help with a Seth Thomas "Cymbal #1" Tambour 8-Day Mantel Clock "89K"
    By SethThomasCymbol#1 in forum Clock Repair
    Last Post: 09-21-2008, 07:18 PM
