NOTICE Notice: This is an old thread. The last post was 1908 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 4 of 4
    Default Howard Miller Grandfather clock chimes will not work
    Howard Miller Grandfather clock model # 610-754.
    Clock had not worked for some time, pulled the movement from clock, cleaned movement, the cable was off track on two pulleys, repair that problem and placed back into clock. Keeps time perfectly but the chimes will not work.
    Registered user.
    Dec 2007
    South east USA
    204
    Default Re: Howard Miller Grandfather clock chimes will not work (By: suemsp)
    Hello. How long has this clock been in service? And have you checked for pivot wobel on the front chime side under the 1/4 hr wheel and the chime lock wheel? good luck ..................TTD
    Default Re: Howard Miller Grandfather clock chimes will not work (By: The Tick Doc)
    A good cleaning requires that the movement be taken apart. At that time, other issues can be addressed and corrected. It might be time for another movement. Contact Mark Butterworth (see advertising top of page) for a quote.
    Default Re: Howard Miller Grandfather clock chimes will not work (By: shutterbug)
    Suem,
    Wiggle the disk that operate on the front of the plate on the chime side. These are on the third and forth wheel extended arbors. If they wiggle around then the movement is worn out. It is best to replace it.
    Common for the chime side to wear out long befor the other trains.
    I am assuming that the chime train is being released normally.
  1. Howard Miller Grandfather clock out on sink
    By 6020rich in forum Clock Repair
    Last Post: 03-23-2010, 09:58 PM
  2. Clock movement will not work in case
    By rkw in forum Clock Repair
    Last Post: 04-01-2009, 05:07 PM
  3. Howard miller grandfather clock need help.
    By topkat4you-12 in forum Clock Repair
    Last Post: 12-24-2008, 11:46 PM
  4. Howard MIller Grandfather clock help
    By whatgoesaround in forum Clock Repair
    Last Post: 07-22-2008, 10:16 PM
  5. Howard Miller Grandfather clock
    By RJSoftware in forum Clocks General.
    Last Post: 11-19-2006, 09:38 AM
