Goal: $300, Received: $275.00 (92%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2057 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 7 of 7
    Registered user.
    Dec 2011
    Tampa, Florida
    Default Help identifying black slate mantle clock
    I need help identifying a black slate mantle clock. I believe it to be French but can find no markings.
    The winding mechanism is what got my attention. It has no key holes on the face but winds from a knob that is pulled out of the center of the face. Turn clockwise to wind the chime and counter to wind the time.
ID:	112572   Click image for larger version.
ID:	112573   Click image for larger version.
ID:	112574   Click image for larger version.
ID:	112575   Click image for larger version.
    Default Re: Help identifying black slate mantle clock (By: brueggy)
    Interesting tandem wind clock. I would agree with what I can see, looks to be French.
    Larry Pearson, FNAWCC* #35863
    Nov 2002
    39,820
    Default Re: Help identifying black slate mantle clock (By: lpbp)
    Hi, Brueggy, welcome to the message board. Have a close look at the backplate of the movement, using a magnifying glass, to see if you can find any trademark stamps. I agree with Larry, it certainly looks very French to me. Never seen a French tandem wind clock before.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Registered user.
    Dec 2011
    Tampa, Florida
    Default Re: Help identifying black slate mantle clock (By: harold bain)
    There are numbers stamped on the bottom of the back plate:
    3 7
    5 2
    and on the top, a very faint scribing of what looks like"
    AH624
    other than that nothing.
    The chime has LP stamped into it.
    Brueggy
    Registered user. jmclaugh's Avatar
    Jun 2006
    Devon
    3,570
    An interesting an unusual clock, I've never seen a French movement wind like that and it certainly appears to be French. Are the barrels in line or is it using gearing to wind them? From the photo it seems the movement isn't deep enough for them to be line.
    The arbor for what appears to be a suspension adjustment protrudes much further than it should.
    Jonathan.
  6. #6
    Registered user.
    Dec 2011
    Tampa, Florida
    Default Re: Help identifying black slate mantle clock (By: jmclaugh)
    The barrels are horizontal left and right.
    The suspension adjusting arbor is out in the picture to show where it is. It sits flush with the face. The center winding arbor pushes in as well to appear to be a large knob on the hands.
  7. #7
    Registered user.
    Dec 2011
    Tampa, Florida
    Default Help identifying black slate mantle clock (By: brueggy)
    I am trying to identify a black stale mantle clock. This is a very heavy mantle clock. We think it is french. It has a very unique winding mechanism. It is an 8-day movement that is wound by an arbor (handle) that is on the face of the clock in the center where the hands meet. There is no key as this arbor is fixed in place. There are two drums holding the springs, one left and one right at the same level. You open the beveled glass crystal and extend the arbor on a knob in the center of the face where the hands come together. Turn clockwise for strike and counterclockwise for time. There is also an adjusting arbor at the top of the face that extends for minor corrections without the need to adjust the pendulum from the rear.
    There are no markings on the face. On the movement the back has stamped the numbers 3 and 7 a quarter inch from the bottom and 5 and 2 below that.
    I looks like a very faint AH629 hand scratched into the top of the back plate.
    Also on the striking coil at the base are LP in an oval stamped.
    Thanks for your help
    Forgive me if this is a duplicate. I asked this before the software upgrade and now cannot find the post.
ID:	115497   Click image for larger version.
ID:	115498   Click image for larger version.
ID:	115499   Click image for larger version.
ID:	115500   Click image for larger version.
  1. French Black Slate Mantle clock?????
    By RobWheatley in forum Clocks General.
    Last Post: 01-26-2012, 05:10 PM
  2. Help identify Seth Thomas mantle clock
    By Oofloom in forum Clocks General.
    Last Post: 04-02-2011, 09:13 AM
  3. Help Identifying A Slate & Marble Clock
    By ChrisBeattie in forum Clocks General.
    Last Post: 04-07-2006, 03:28 AM
  4. Help identifying Seth Thomas Mantle clock
    By Peter in forum Clocks General.
    Last Post: 04-02-2004, 06:56 AM
  5. Need Help Identifying a French Mantle Clock
    By mlschlot in forum Clocks General.
    Last Post: 03-13-2004, 06:14 AM
