Goal: $300, Received: $225.00 (75%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2058 days ago. If your post is not directly related to this discussion please consider making a new thread.
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
    Default Cuckoo Wire replacement question
    What do you guys use for lift wire, door wire, etc.? I've tried several kinds of wire, and none seem to do what I want. Either too thick, too soft, too brittle or too fragile .... etc. The wire you can order from the suppliers for cuckoo's seems just right. What the hoot is it?
    Registered Users
    Sep 2006
    metro NY area
    3,951
    Default Re: Cuckoo Wire replacement question (By: shutterbug)
    Quote Originally Posted by shutterbug View Post
    Do you mean the wire that opens the door, or the one from the movement to the bellows, or the one from the bellows that tilts the bird? It depends, as they are all different. As best as I recall, wire from a paper clip can be used for the door linkage wire. The wire for the bird is much thinner. The movement lift wires usually don't go missing.
    Registered user. Tony10Clocks's Avatar
    Aug 2010
    Northant's
    1,640
    Default Re: Cuckoo Wire replacement question (By: Thyme)
    I don't do Cuckoo clocks. But i do have an assortment of welding wire. Mig welding wire from 0.8, 1.0, 1.2mm, flexible but not brittle and some Tig welding wire 1.6mm . Always comes in handy
    Too many clocks and not enough time, Tony
    Default Re: Cuckoo Wire replacement question (By: Tony10Clocks)
    Quote Originally Posted by tonyboy View Post
    Good idea. I was at Menards today, and found something called "dark annealed steel wire" that really looks promising too. If it fails the test I'll try looking for welding wire. Thanks!
    Thyme - for now, I'm looking for 'door' wire
    Registered User tom427cid's Avatar
    Mar 2009
    Moultonborough,NH
    1,359
    Hi,
    For linkage in cuckoos that I repair I have found that 22 ga picture hanging wire works for the door and the trip wire for the bird. The 22 ga is just a little light for the lift wire an 18 or 20 ga is best for that. Picture wire is generally available at most hardware stores.
    Hope this helps.
    tom
  6. #6
    Aug 2010
    Northant's
    1,640
    Default Re: Cuckoo Wire replacement question (By: tom427cid)
    Just a note:
    22 Gauge = 0.8mm
    20 Gauge = 1.0mm
    18 Gauge = 1.2mm
  7. #7
    If you find, say some 20 ga. wire, that is to soft. It can be twist hardened. Clamp one end of the wire in the big vice and the other in the ole cordless drill. Best to use several feet. Then pull the wire tight with the drill running slowly. Best not to get carried away 4 or 5 turns per inch will do about all that can be done with this method. It's hardness is increased enough to make a noticeable difference.
    Not unusual to see twist hardened wire in a clock movement, once you notice it the first time.
  8. #8
    Nov 2002
    39,818
    Default Re: Cuckoo Wire replacement question (By: Willie X)
    I'm working on a very large old cuckoo and quail, and the previous repairman had soldered some wire together for the bellows lift wires (they are much longer than what the suppliers have). I used cutoff rod from American suspensions to replace them, seems to work well enough, and looks OK.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
  9. #9
    Default Re: Cuckoo Wire replacement question (By: harold bain)
    As I suspected, there's lots of different approaches. I'll try a bit of all of them until I find the "one". Thanks to all for the suggestions!
  10. #10
    Registered user. Mike Phelan's Avatar
    Dec 2003
    West Yorkshire, England
    9,823
    Welding rod or mild steel wire from model engineers' shops. Good for levers and pendulums on American clocks as well.
    Mike - banned member of the throwaway society. :o
  11. #11
    Default Re: Cuckoo Wire replacement question (By: Mike Phelan)
    None of the regular wires in a cuckoo carry a very big load, and they don't have to be particularly strong or stiff. Any malleable wire within reason will do.
    Measuring stuff on hand, here's what I find:
    A commercial bellows-lift wire is soft steel 0.039"
    A small paper clip is 0.032"
    A large paper clip is 0.049"
    I have a coil of 0.040" soft steel wire that I use for almost everything on a cuckoo clock: Bellows lift wire, bird-tail lift wires, eyelets, staples, etc. I've also used paper-clip wire sometimes.
    For door wires (between bird & door, between little man & door), I use #22 brass wire (0.027"). Heck, there's no stress on it...there are no stiff hinges on cuckoo doors.
  12. #12
    Default Re: Cuckoo Wire replacement question (By: bangster)
    Yeah, I tried brass wire .... but it breaks about the second time you try to bend it
  13. #13
    Dec 2003
    9,823
    Brass wire / rod is hardened when it's drawn; you can anneal it by heating up to near a red heat, but it's too soft for this purpose. Needs to be steel.
  14. #14
    Hmm. I haven't observed the breakage problem with brass door wires.
    For door wires, I think you generally want something smaller gauge than lift wires. Only ready source of steel I can think of is SPC (small paper clip). Or maybe annealed music wire. Or do they still make women's hair pins?
    Heck, go with whatever works for you. Remember the minimal job a door wire has to do.
  15. #15
    The paper clip idea is pretty good. I'll have to try that On a related note, what is the preferred method of fixing a door hinge that is loose (just wire). It's an old clock, so replacement is not an option, and neither is repositioning it.
  1. Cuckoo clock movement question
    By mckpaul in forum Clock Repair
    Last Post: 03-25-2012, 09:51 PM
  2. Cuckoo Governor replacement question.
    By Jeff C in forum Clock Repair
    Last Post: 07-15-2010, 11:21 PM
  3. Cuckoo clock weight questions
    By eskmill in forum Clocks General.
    Last Post: 10-15-2005, 08:46 AM
  4. Cuckoo WIRES question
    By bangster in forum Clock Repair
    Last Post: 05-01-2005, 11:12 AM
  5. Musical cuckoo clock sequence question
    By DenisG in forum Clock Repair
    Last Post: 01-12-2005, 06:13 AM
