Results 1 to 8 of 8
Thread: Neon Ad Clock (Telechron)
    Default Neon Ad Clock (Telechron)
    I just purchased a neon ad clock. The neon is missing but the clock and ad drum work. The transformer is present. I need a picture the interior of the clock with neon so I can figure out what I am missing.
    I also need to purchase the dial & drum bezel and serial numer plate. Any hints on where to look.
    Apr 2004
    Mesquite, TX
    8,862
    usa  us texas
    NAWCC
    Default Re: Neon Ad Clock (Telechron)
    We will need to see at least two pictures of the clock, inside and out before we can counsel.
    Later we can move this to "Early Electric Clocks" forum, a little further down the list for more expertise there. Thanks!
    Pictures as requested.
    Nov 2002
    28,768
    canada  ca ontario
    NAWCC
    Hi, Tom, welcome to the message board. Your motor appears to be going to the transformer. It should run on 110 volts ac. For the parts you need, contact Wayne at Waynes Neon Clocks:
    http://www.waynesneonclocks.com/
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Apr 2004
    Mesquite, TX
    8,862
    usa  us texas
    NAWCC
    Yes, the motor and transformer primary are connected in parallel. There may be a switch for turning off the neon. It appears the neon was a small circular tube. The wire at top and probably two or more others secured the tube. Perhaps Wayne will know the original color. I'd choose a color that pleases me.
    Awsum little clock! Congrats.
  6. Default Re: Neon Ad Clock (Telechron)
    Wish I had one....
    Best ~
  7. #7
    Feb 2005
    Wi
    156
    usa  us wisconsin
    NAWCC
    I have copies of the original ad cards for this clock if you need some contact me.
  8. Default Re: Neon Ad Clock (Telechron)
    I have a clock very similar to this, only it isn't a rotating fliper version, it has a slot to place a glass/plexiglass painted ad...does anyone know where I might be able to find an original or good repro??
    Paul
  1. Neon Ad Clock (Telechron)
    By tomr1111 in forum Clocks General.
    Last Post: 12-05-2011, 09:15 PM
  2. Telechron Neon Ad Clock
    By Gordon Andersen in forum Electric Horology
    Last Post: 10-05-2009, 07:15 AM
  3. Neon Ad Clock
    Last Post: 07-16-2009, 06:22 PM
  4. Lackner Neon Glo Clock Motor
    By DenisG in forum Electric Horology
    Last Post: 08-06-2005, 10:25 AM
  5. Pam ad clock hastings piston rings
    By DML Clocks in forum Electric Horology
    Last Post: 03-09-2004, 05:16 AM
