Goal: $300, Received: $350.00 (117%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 1987 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 2 of 2
    Default waterbury clock suspension rod
    Hello my steeple clock needs a new suspension rod. The movement says Waterbury co. 6 1/2 inch. any idea where to get one that is already preshaped? or do i have to make one ?...the spring is 1/4" wide and about 1 5/8" long, not to sure about the thickness though. Overall lenght of the spring and rod is 6 1/2"...thanks john
    Default Re: waterbury clock suspension rod (By: narrowfarm)
    Narr,
    You will have to make one from a commonalty available blank. .003" spring thickness is good. The spring part may need to be trimmed too. Longer is OK as long as the crutch loop is about 1/4" onto the rod part.
  1. Suspension Rod for a small Asian wll clock.
    By plove53 in forum Clock Repair
    Last Post: 06-02-2012, 11:18 AM
  2. Japan Takeda 31 day wall clock suspension rod spring
    By narrowfarm in forum Clock Repair
    Last Post: 01-23-2012, 10:32 PM
  3. Waterbury 8-day suspension rod
    By David Hill in forum Clock Repair
    Last Post: 06-28-2010, 08:45 AM
  4. INVAR ROD & MASTER CLOCK SUSPENSIONS
    By MARKSMASTERS in forum Clock Repair
    Last Post: 07-23-2006, 06:18 PM
  5. Suspension Rod Spring Repair for Poole Clock
    By Kobayashi Maru in forum Clock Repair
    Last Post: 02-01-2006, 03:04 PM
