NOTICE Notice: This is an old thread. The last post was 2084 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 6 of 6
    Registered user. LloydB's Avatar
    Feb 2006
    La Crosse, Wisconsin's West Coast
    1,451
    Default Trademark: Square/ Diamond with S
    A friend has a clock with this trademark
    It's a circumscribed Square,
    a 2nd square (diamond orientation) inscribed inside
    and there's a large capital 'S' within the diamond.
    It's similar to the Seikosha Trademark, but that
    one more typically has a circumscribed Circle with
    the diamond square inside, etc.
    Is this possibly a variation of the Seikosha <tm>,
    or is it identifiable with some other manufacturer?
    The round clock face measures about 13", Roman
    numeral chapter, and marked "Regulator". There
    are 2 winding arbors (horizontally spaced below
    the center) but no sub. seconds.
    It has a short drop pendulum, and a circular, plain,
    dark, wooden surround case.
    Any suggestions appreciated, and thanks.
    Default Re: Trademark: Square/ Diamond with S (By: LloydB)
    Lloyd:
    Senkosha and Hayashi used an "S" inside a square, all inside a diamond (see Charles Davis Website here), but yours is apparently t'other wa around. Are you able to post a picture of the logo? If Charles Davis happens upon this thread, he maybe able to shed some light.
    All this, of course, assumes the clock is Japanese.
    “If one tells the truth, one is sure, sooner or later, to be found out.” - Oscar Wilde
    Feb 2006
    1,451
    Default Re: Trademark: Square/ Diamond with S (By: Steven Thornberry)
    Yes, much like those, but with the 'horizontal' diamond
    on the outside. I'll attempt to get a picture, but here's
    the drawing he provided
    Thanks for the suggestions -- interesting that none of
    the trademarks at that site have the external square.
    Could the dial be one of the replacement dials that Swiggart used to sell? Did they have a 'J" with the "S".
    Feb 2006
    1,451
    Default Re: Trademark: Square/ Diamond with S (By: John Arrowood)
    Quote Originally Posted by John Arrowood View Post
    Hi John; According to the new owner, the mark is on the movement,
    I didn't observe it directly. I'll try to get a look.
    However, other than "Regulator" in an arc over the center, there's no
    mark on the face/dial, which I did examine and measure. It certainly
    appeared to be the original dial.
  6. #6
    Feb 2006
    1,451
    I'm re-informed that once the dial was removed (aluminum-backed,
    BTW) and the movement illuminated, that external 'square' morphed
    into a circle. So, it's Seikosha after all: Circle with inscribed diamond
    and letter S.
    The only other mark is a numeral 6 just above that trademark,
    located on the dial-side plate, left lower corner.
    I'll arrange to post a couple of pictures, if anyone has an interest.
    Thanks for the suggestions, the original information was incorrect.
  1. Replies: 5
    Last Post: 07-29-2012, 03:20 AM
  2. Replies: 7
    Last Post: 08-23-2011, 12:19 PM
  3. Trademark: Balance Wheel with "W" in it?
    By wierclock in forum Clocks General.
    Last Post: 01-26-2011, 12:51 AM
  4. Illinois wristwatch question-Square with square seconds chapter-not round
    By tlktchr@bellsouth.net in forum Wrist Watches
    Last Post: 04-01-2006, 12:07 PM
  5. Help with German Trademark
    By Time-Saver in forum Clocks General.
    Last Post: 06-17-2005, 08:50 AM
