Results 1 to 7 of 7
Thread: King Edward Rockford staff
    Default King Edward Rockford staff
    Any help appreciated, I've got a King Edward serial# 617573 HC with a broken staff. Can anyone help with sourcing??
    Default Re: King Edward Rockford staff
    I am away from my references right now but you are dealing with what would be a Rockford model 10. I hope that gives you a bit of help.
    I will check back if you still need info.
    Darrah
    Chap. 15, 124, 139, 149, 168
    Model 10, then. I think Dashto has those, I'll email him. Thanks so much. BTW What reference might you be using?
    Reference to identifying the model?
    http://www.nawcc-ch149.com/pw_dbresearch.html
    This link will get you to the Rockford database, just enter the sn and click on any field that is listed below. You can use Rockford article below (Artzner) to get some idea of model recognition.
    Will, Dashto has a ref chart for staffs. Model 10 uses a 545 or 560 (or 660), I can't read the latter very well. Remove yours and compare.
    I appologize but got busy when I got home and did everything else but look up the staff number. I will make a note and try to confirm it again tonight. DA
    Darrah
    Again, I appreciate your efforts. I had used the Database before and it simply described the model as "special". Grade 845. I'm hoping the model 10 staff is the ticket. I emailed an order but Tom at Dashto is out of town for a while.
  6. #6
    Ok here are the staff numbers for the model 10 Rockford King Edward:
    585
    880 (double roller)
    Darrah
  7. #7
    Worked well, thanks for the help!
  1. Rockford staff needed
    By Randy Creps in forum Watch Repair
    Last Post: 10-31-2011, 02:44 PM
  2. Replies: 1
    Last Post: 10-13-2008, 09:54 AM
  3. Rockford staff No
    By beta21 in forum American Pocket Watches
    Last Post: 10-20-2004, 02:10 AM
  4. Waltham and Rockford staffs info
    By 4thdimension in forum Watch Repair
    Last Post: 06-03-2004, 01:10 AM
  5. Rockford 18S Model 2 staff
    By Tom McIntyre in forum American Pocket Watches
    Last Post: 03-01-2002, 08:24 AM
