Goal: $300, Received: $115.00 (38%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2099 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 6 of 6
    Default ultrasonic cleaning solution for watch movements
    I read that paint thinner is a good ultrasonic cleaning solution for watch movements. Anyone have any good suggestions? I recently used a water based on a Waltham Royal movement and it worked out well. The watch runs great....but i read that water based is not recommended.
    Registered user.
    Jul 2011
    Marysville Washington
    111
    Default Re: ultrasonic cleaning solution for watch movements (By: finiteguy)
    I use L&R non ammoniated solutions for general cleaning, One-Dip for hairsprings, but I'm hearing that there's a newer hairspring cleaner that is cheaper and that doesn't have the fumes. Zenith 707.
    Randy
    Dec 2006
    Houston
    1,151
    Default Re: ultrasonic cleaning solution for watch movements (By: Randy Beamer)
    I use paint thinner (mineral spirits) as an initial rinse after using L&R petroleum based watch cleaning solution. I give the parts a final rinse in Coleman lantern fuel as is leaves no residue and contains a rust inhibitor.
    Darrah
    Chap. 15, 124, 139, 149, 168
    Registered user.
    May 2011
    Plano, TX
    213
    Default Re: ultrasonic cleaning solution for watch movements (By: darrahg)
    Quote Originally Posted by darrahg View Post
    Since I am new to this I have a question: Are we talking about wristwatch movements, pocket watch movements or both as it rates to petroleum based cleaning solutions and rinse?
    Thanks,
    AL
    Dec 2006
    Houston
    1,151
    Default Re: ultrasonic cleaning solution for watch movements (By: EverydayCat)
    I use it on wrist and pocket watches and clocks. I make sure the cleaner and rinse are new or almost new (very clean) with the watches. The cleaning solution can get a little color (dirty) with clocks. I don't mean any disrespect to clocks, they just have a broader tolerance and my rinses are clean for all movements.
    Oh, watch cases are cleaned in older solutions.
    Darrah
  6. #6
    If it contains a rust inhibitor, it by definition leaves a residue. It would be nice to avoid that. Another solvent that you can use that won't leave a residue is VM&P Naptha (aka Ronsin Lighter Fluid).
    If you go back about 5 years, you will find a long thread that I started where I was looking for homemade alternatives to the L&R solutions... this was before the new board, so you can't search on Gnomon as a user name, but probably as a text string.
    -Chuck Harris
  1. Lens Cleaning Tissues for Watch Work?
    By mikey1968 in forum Watch Repair
    Last Post: 09-13-2011, 03:07 PM
  2. Help, I need a digital camera for watch movements..
    By clkhby in forum Wrist Watches
    Last Post: 03-15-2008, 11:04 AM
  3. Homemade ultrasonic cleaning solution recipe wanted.
    By rlxdeusirae in forum Wrist Watches
    Last Post: 03-17-2006, 11:41 AM
  4. Proper cleaning solution for amateur home cleaners.
    By Don Dahlberg in forum American Pocket Watches
    Last Post: 02-21-2004, 09:31 AM
  5. Cleaning solutions for an ultrasonic cleaner
    By Dave_P in forum Horological Tools
    Last Post: 11-10-2003, 08:45 AM
