Goal: $300, Received: $225.00 (75%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2146 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 10 of 10
    Registered user.
    Aug 2011
    Vancouver, BC
    Smile Need identifying watchmakers lathe
    Hello to all. I'm new to this board and I'd like to have a question. Some of you who may recognise the lathe I inherited from my brother in the early 80's. He used to repair swiss watches in the 50's 60's and 70's. He passed away and I didn't have the chance asking him about what's the make of this lathe before. Also got another lathe along with this one that I know for sure was a nickel plated Boley.I've traded the Boley quite some time ago for a 60's australian 9" Hercus model that suits my need better.
    This late looks similar to the modern day Bergeon . It has a D bed with the flat section on top. Collet thread size is 7mm and parts of the lathe is painted black enamel. Interestingly, there's is no name stamped on parts of the lathe, only one component I see the maker of Lorch stamped on.
    Your input is appreciated.
ID:	100010   Click image for larger version.
ID:	100011   Click image for larger version.
ID:	100012   Click image for larger version.
    Registered user.
    Feb 2008
    Germany
    284
    Default Re: Need identifying watchmakers lathe (By: Cornavin60)
    Hello,
    maker was Andrae & Zwingenberger, Limbach in eastern Germany.
    Lathe bar should be 25mm diameter.
    Frank
    It looks very much like a GDR-made Andrš & Zwingenberger lathe:
    http://www.lathes.co.uk/andra/
    They are said to be quite good.
    Per
    -> posts merged by system <-
    Quote Originally Posted by Per G View Post
    Oops - 2nd place
    Registered user.
    Aug 2011
    Vancouver, BC
    Thumbs up Re: Need identifying watchmakers lathe (By: Per G)
    Thanks guys ,it was quick. Interesting about the different finishes . Mine doesn't have the grove on the bed , and the cross slide is engine turned .Overall finish is excellent.
    This is incorrect measurement of lathe's spindle opening. The drawbar and the *unthreaded* part of collect, measure these and it should be very close to 8mm. I hate that when somebody don't say this or state the collet thread size this is not correct way to measure.
    It helps with selling or buying more pieces that use 8mm collet design. Also do not part any of the items, when watchmakers buy their new lathes they were sold as one set with all the goodies.
    Cheers, Watchfixer
  6. #6
    Registered user.
    Aug 2011
    Vancouver, BC
    Smile Re: Need identifying watchmakers lathe (By: Watchfixer)
    Watchfixer, sorry about the misinformation.I'm not a watchfixer ,just measured the threadsize on the collet with my caliper.I'm sure the bore will measure 8 mm as you suggested.
    Ps; anyone have an idea what this box set worth?
  7. #7
    Good idea to measure as suggested. Not the bore. The collet shanks and drawbar is the usually actual size.
    Cheers, Watchfixer
  8. #8
    Quote Originally Posted by Cornavin60 View Post
    A while ago I saw a box very much like yours on German eBay with an asking price of well over 1.000 Euro.
    You could check on www.ebay.de for andrš zwingenberger now and then. There are usually some lathes and parts up for sale, they are not all that rare.
    Per
  9. #9
    Registered user.
    Sep 2008
    BC interior Canada
    7
    Default Re: Need identifying watchmakers lathe (By: Per G)
    nice lathe I would say probably much more than 3000 in Canada I just spent 1000 for a very basic incomplete ww setup, (no cross slide none of the attachments i wanted) if your interested in selling that sometime let me know lol
  10. #10
    Registered user.
    Aug 2011
    Vancouver, BC
    Smile Re: Need identifying watchmakers lathe (By: D. Munroe)
    Dr.opie, if you 're interested, make me an offer I couldn't refuse. This unit is definitely good quality with the engine turn finish too that I don't see on the web for other makes. This box set is quite heavy as a whole and I hoped to find someone locally though.Thanks for your interest , may be something will work out.
  1. Mechanical Wristwatch Help to Identify Watchmaker Lathe Part
    By joedawolf in forum Watch Repair
    Last Post: 07-17-2012, 11:14 AM
  2. Watchmakers' Lathe Book
    By David Robertson in forum Horological Tools
    Last Post: 11-28-2006, 08:55 AM
  3. Ball bearing watchmaker lathe headstock lubrication
    By Larry Vanice in forum Horological Tools
    Last Post: 01-21-2006, 01:30 AM
  4. Watchmakers Lathe or Unimat3 for clock repair
    By ticktock in forum Horological Tools
    Last Post: 11-16-2004, 08:28 PM
  5. Need a watchmaker
    By Kezwan in forum Watch Repair
    Last Post: 11-14-2004, 12:37 AM
