Notice: This is an old thread. The last post was 681 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 8 of 8
08-07-2011, 05:06 PM #1Registered User
- Join Date
- Feb 2008
- Posts
- 43
LeCoultre 8 day clock staff replacement
Has anyone ever replaced a staff in one of the 8 day LeCoultre clocks, it is one of the small desk top clocks. This particular one is a 240/1 movement.
It needs the staff replaced, the problem I have, with my watch tools, I can't see how to take the balance or roller off without the other one being off first.
I have two styles of roller removers and the balance is in the way. Same with trying to take the balance off, the roller is in the way. They are both mounted about 4 mm apart which is really wide.
Any suggestions?
08-07-2011, 06:24 PM #2
Re: LeCoultre 8 day clock staff replacement
Can you post some pictures, might help to see what you are up against.
08-07-2011, 06:35 PM #3Registered User
- Join Date
- Mar 2010
- Posts
- 21
If your talking about being able to remove the roller I have upon occasion placed the roller in the appropriate sized collet (providing the roller is the standard round style) for my watchmakers lathe and very carefully with moderate preasure and a twisting action removed the roller from the staff (It should be frictioned on). At that point you should be able to remove the staff in the normal way. Make sure you take the hairspring off before doing this
08-07-2011, 07:51 PM #4Registered user.
- Join Date
- Jun 2011
- Posts
- 1,205
Really need to see a picture of these, btw this brand is extremely expensive.
Cheers, Watchfixer
08-08-2011, 11:52 AM #5
Would it be more like a pocket watch movement than a wrist watch if it's a table clock......
08-08-2011, 06:43 PM #6Registered User
- Join Date
- Feb 2008
- Posts
- 43
I may try to get a decent picture. The movement in size is similar to an 18 size pocket watch, but the balance is much smaller and very fragile. The balance is about the size around of a men's swiss wristwatch, the hair spring is really small. The roller is not located right next to the balance, there is a large space between the balance and roller.
I think the trick of holding it in a collet might work, I hadn't thought about that.
It is a really nice little clock and the rest of it is in mint condition.
08-08-2011, 08:43 PM #7Registered user.
- Join Date
- Jun 2011
- Posts
- 1,205
Yes, to make 8day to work, either the barrel had to be huge or make balance wheel real tiny.
Macro photos are cool, come on.
Cheers, Watchfixer
08-09-2011, 01:23 AM #8
I was wondering why my two wittnauer 63 balances looked so teeny. Thank you.
Rob
A Vintage Watch
Replacing Torsion Springs on 400 Day Clocks
By leadpot in forum 400-Day, Atmos and other Torsion ClocksReplies: 9Last Post: 11-17-2006, 01:29 PM -
Details & photos of some of my 400 day clocks
By Ingulphus in forum 400-Day, Atmos and other Torsion ClocksReplies: 5Last Post: 07-01-2006, 02:31 AM -
Measuring 400 Day Clock Suspension Springs
By gary G in forum 400-Day, Atmos and other Torsion ClocksReplies: 7Last Post: 07-04-2005, 04:28 PM -
400 day clock repair
By Doug Campbell in forum 400-Day, Atmos and other Torsion ClocksReplies: 3Last Post: 07-08-2001, 08:40 AM -
400 day clock runs slow
By dantheman in forum 400-Day, Atmos and other Torsion ClocksReplies: 9Last Post: 05-14-2001, 01:21 AM
About the Message Board
This will be an ongoing blog to chronicle the development and use of the NAWCC Message Board. Please reply with your thoughts as you feel appropriate. June 2013 marks the deployment of the last edition of vBulletin V4. We will continue using this version of the software until vBulletin V5 has been widely deployed and had a thorough shakedown. That may take as much as 3 years. In order to freshen the look of the message board, several changes have been made in this deployment. The most...
05-31-2013, 04:23 PM in Tom McIntyre
