NOTICE Notice: This is an old thread. The last post was 4018 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 5 of 5
    107WestStreet
    Guest
    Default Small black forest alarm clock runs too fast.
    I cleaned the clock and now it runs like the dickens, can't stop it. In fact, runs about 2 hours fast a day. It has a crude balance wheel with hairspring.
    107WestStreet
    Guest
    Default Small black forest alarm clock runs too fast. (By: 107WestStreet)
    Registered user. Mike Phelan's Avatar
    Dec 2003
    West Yorkshire, England
    9,823
    Hi 107
    How was it before? Crude balance wheel? Wossat?
    Suggestions, assuming it is a pin pallet escapement:
    Pallet pins worn or bent and drop occurring on impulse face.
    Lack of power causing a poor arc.
    Hairspring pinned too short
    Hairspring sticky or magnetised and turns sticking together
    Regulator index not on outer turn of spring.
    Worn or incorrect endshake on balance pivots (assuming cone pivots)
    HTH
    Mike - banned member of the throwaway society. :o
    107WestStreet
    Guest
    There is a hairspring. By crude, I mean nothing as well made as a watch balance wheel. It has a pin pallet.
    That spring has to be dry. If you oiled it, or any part it touches you will have to start over (sorry)
  1. Ansonia Alarm Clock Runs too Fast
    By jmtaylo3 in forum Clock Repair
    Last Post: 06-29-2012, 12:11 AM
  2. Black Forest Cuckoo Clock Pendulum too heavy?
    By elblogeo in forum Clock Repair
    Last Post: 01-24-2007, 06:36 PM
  3. clock running too fast
    By v-regulator in forum Clocks General.
    Last Post: 09-06-2006, 12:42 PM
  4. replacing spring on small black forest alarm clock
    By 107WestStreet in forum Clock Repair
    Last Post: 02-09-2006, 06:10 PM
  5. linden Black Forest Alarm Clocks
    By 107WestStreet in forum Clocks General.
    Last Post: 08-11-2005, 07:48 AM
Members who have read this thread: 4
