Goal: $300, Received: $360.00 (120%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2112 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 4 of 4
    Mar 2011
    Kentucky
    42
    Default Stem Extreemely Difficult To Pull Out
    Hello all,
    I have a 0 size Waltham pocket watch in a 20 year warranted Crescent case. The winding stem is extreemely difficult to pull out to the setting position with the movement installed and just very hard to pull out with the movement removed. It clicks down to the winding position easily every time.
    Does anyone have any suggestions as to what I can do to address this problem? I have not been able to pull the stem free of the case by hand and have not tried with any tools.
    Thanks in advance!
    B ob
    Registered User richiec's Avatar
    Feb 2007
    Brick, Ocean, NJ
    5,249
    Blog Entries
    Default Re: Stem Extreemely Difficult To Pull Out (By: In The Details)
    Maybe a bent or broken sleeve or needs a cleaning and lube of the setting mechanism.
    Default Re: Stem Extreemely Difficult To Pull Out (By: richiec)
    With the movement removed from the case, place a small drop of oil onto the stem and sleeve area in the pendant. This should solve the problem.
    tom
    Mar 2011
    Kentucky
    42
    Default Re: Stem Extreemely Difficult To Pull Out (By: Tom Huber)
    Sounds good. I will oil the stem as advised. Thank you both!
  1. Two OG Clocks-Difficult To Replace Backs/Doors?Etc?
    By popeye in forum Clock Case Restoration and Repair.
    Last Post: 03-26-2015, 04:17 PM
  2. Mechanical Wristwatch Stem pulls Out
    By bbodnyk in forum Watch Repair
    Last Post: 05-30-2011, 09:23 AM
  3. 2824 movement stem pulls out
    By pickmark in forum Watch Repair
    Last Post: 06-14-2007, 11:38 AM
  4. Howard 16S 17J OF/Difficulty pulling out the stem
    By Jerry Bryant in forum American Pocket Watches
    Last Post: 04-02-2007, 01:23 AM
  5. Difficult to Wind??
    By biker4 in forum Watch Repair
    Last Post: 04-20-2005, 10:53 AM
