Goal: $300, Received: $115.00 (38%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 1519 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 7 of 7
    Default French brevete clock info needed
    I have this small Brevete french made clock that looks like a travel clock. I was hoping someone might have info on the type of clock it is and the time period its from. I'm not an expert but I couldnt find much information on this clock. Is it rare? The best part is it still works.
ID:	95776   Click image for larger version.
    Default Re: French brevete clock info needed (By: whitman75)
    Brevete basically means "Patented". Can't say much else, but it looks like a good clock.
    "A good gong sells the clock!" - Justin A. Olson
    Principal Administrator John Hubby's Avatar
    Sep 2000
    The Woodlands, TX
    11,022
    Default Re: French brevete clock info needed (By: chimeclockfan)
    Basically it's a French time/alarm that most likely was a bedside or vanity clock, generally classified under novelties. As CCF says, "Brevéte" means patented so will need some other info to see if a maker can be determined. There may be a logo stamped on the movement underneath the back cover. Also, I notice the alarm "on-off" lever seems to be missing. Based on the style of the case, dial, and numbers it appears to be 1920's-1930's vintage.
    Default Re: French brevete clock info needed (By: John Hubby)
    Here are some other markings on the clock. Brevete sgdg. Reveil. R.A.
    Registered User soaringjoy's Avatar
    Feb 2009
    7,240
    Whitman,
    Brevete S.G.D.G. means "sans garantie du gouvernement", actually
    saying that the government takes no responsibility to the patent being
    "new".
    "Reveil" means alarm clock and R + A are "retardé" and "avancé" for
    the "slower / faster" regulation of the movement.
    Jurgen
  6. #6
    Registered user.
    May 2013
    Greenville, South Carolina, USA
    Hello. You may want to search down the "Brevete a La Fontaine", "l'eveque" road. The two Montigny brothers, Pierre and Camille were inventors and custom gunsmiths. Your clock reminds me of the unique custom trigger workings connection they had in Brussels Belgium. Your clock looks similar to their work, 1837-1849, and up to 1869. Search under clocks in museums in Brussels, Belgium. Also,
    "Musee de l'industrie de Belgique 1869"
  7. #7
    Feb 2009
    7,240
    Default Re: French brevete clock info needed (By: NWestSCarolinaHistoryBuff)
    Buff, welcome to the message board and thanks for your thoughts.
    The clock does look like 20th century and industrially made, though.
    Jurgen "tempus nostrum"
  1. Mercer Ships Clock Info Needed
    By clocks4u in forum Clocks General.
    Last Post: 02-09-2015, 09:43 AM
  2. French Monnier clock 1885, need info on it
    By Russell Dickson in forum Your Newest Clock Acquisition
    Last Post: 02-20-2012, 05:44 AM
  3. gilbert clock info needed please...
    By RTC1 in forum Clocks General.
    Last Post: 06-08-2006, 12:52 AM
  4. Junghans clock info needed
    By Mike Phelan in forum Clocks General.
    Last Post: 11-29-2005, 02:18 AM
  5. French Figural Clock-Info/Age?
    By popeye in forum Clocks General.
    Last Post: 09-22-2005, 01:58 PM
