NOTICE Notice: This is an old thread. The last post was 2236 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 7 of 7
    Default Looking to find out what this is
    I have a clock my father left me. I have not put it together yet. It has been packed for a few years. The case was cleaned many years ago and I have all weights and parts. Just curios what kind it is. The face says Nataniel Adams, but I cannot find much info on it. Thanks for the help
ID:	91738   Click image for larger version.
    Default Re: Looking to find out what this is (By: jeffreyskoch)
    Not an expert here but looks to be a nice American Tall Case clock, probably 8 day movement. Most likely New England, maybe New Hampshire. About all I can tell you about it but defintely worth restoring. Am sure someone else will give you a more in depth description.
    Nov 2002
    39,628
    Hi, Jeffrey, welcome to the message board. Looks like a fine example of early American craftmanship. Spittlers' and Bailey's American Clockmakers and Watchmakers lists Nathaniel Adams as "Troy, New York, Ca. 1794. White dial clock extant."
    Is the movement brass, or wood? Could you post a few pictures of the movement?
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Quote Originally Posted by jeffreyskoch View Post
    Any chance you can provide decent pics of case and movement?
    RM
    Default Re: Looking to find out what this is (By: rmarkowitz1_cee4a1)
    It is brass here are a few more pictures
ID:	91828   Click image for larger version.
ID:	91829   Click image for larger version.
ID:	91830   Click image for larger version.
  6. #6
    Movement appears to be 8 day and in need of some restoration. Not sure if it is American or English but if I had to guess, I would say English. Case is defintely American and a nice one.
  7. #7
    Registered User Curtis Jackson's Avatar
    Apr 2009
    Columbia, Tennessee
    736
    Default Re: Looking to find out what this is (By: Weight Driven)
    I really have no way of confirming this, but based on what I've seen before, I'd say it is an English movement as well.
    The upper dial posts seem to have come loose. These would have been fixed in place in the top plate of the movement with taper pins that have probably fallen out. Since the dial is now hanging by the bottom two dial posts, be careful to keep them from being bent, broken off or perhaps even warping the top plate of the movement. In this condition, the hands, seconds bit or calendar disk could be bent, warped broken or as well.
    Quite a bit a rust! Was it stored in a damp environment?
    Any markings on the movement?
  1. Tryin to find out more about this clock
    By dawn0 in forum Clocks General.
    Last Post: 09-12-2012, 12:42 PM
  2. Looking to find out some information on this watch
    By dshippy in forum American Pocket Watches
    Last Post: 07-12-2012, 04:32 PM
  3. Replies: 11
    Last Post: 12-27-2011, 01:02 PM
  4. tryin to find out about this clock
    By ljwoodsjr in forum Clocks General.
    Last Post: 11-20-2009, 12:35 PM
  5. Just want to know what this is..?
    By smurf in forum Clocks General.
    Last Post: 07-19-2005, 09:37 PM
