Goal: $300, Received: $215.00 (72%) Contribute Now
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Registered User f.webster's Avatar
    Dec 2009
    Louisville, KY
    594
    Blog Entries
    Default Howard Miller (Hermle 340-020A) Wrench?
    I have a Howard Miller clock that I am repairing. It needs bushing work and so I need to seperate the plates. What has stopped me is the removal of the locking plate and the chime locking cam. They are held in place with what I thought was a hex nut. I have search for a hex wrench to fit and have had no luck. Then I thought it might be a star(?); yet, still no luck.
    Then I was told by a guy in a little hardware store that if it is a Howard Miller Hermle movement it takes a 'special' tool.
    Is this true? If so, where do I get this 'special' tool?
    Default Re: Howard Miller (Hermle 340-020A) Wrench? (By: f.webster)
    I think you mean that they are held by socket set screws and you need a hex key, commonly called an Allen wrench. I don't know the size off hand, but they are metric and only a metric wrench will fit.
    If I have misunderstood completely, please accept my apologies and post a picture of what you are trying to remove.
    Joe
    Dec 2009
    Louisville, KY
    594
    Blog Entries
    Default Re: Howard Miller (Hermle 340-020A) Wrench? (By: Joe D.)
    Joe,
    You are right. I do mean allen wrench. I have searched for a metric allen wrench and those that I found were either too big or too small.
    Help!?! Is there a special size?
    Sorry, I don't have one to check the size right now, but I don't think it's anything special. Hopefully someone else will chime in.
    Joe
    Probably unlikely that Hermle would be manufacturing off-size Allen screws. Something normal in either metric or American ought to fit.
    Unless it's Torx, rather than Allen.
    bangster
  6. #6
    Default Re: Howard Miller (Hermle 340-020A) Wrench? (By: bangster)
    It is a 1.3mm size. We have the allen wrench for it. Also fits the hermle moon gears. $1 each flate rate mailing of $2.
  7. #7
    Default Re: Howard Miller (Hermle 340-020A) Wrench? (By: MARK A. BUTTERWORTH)
    Mark's number is 563-263-6759
  8. #8
    Apr 2004
    Mesquite, TX
    938
    Default Re: Howard Miller (Hermle 340-020A) Wrench? (By: shutterbug)
    I know it's not good to recommend the wrong tool for the job and I would buy a metric assortment but:
    I have had success removing cap screws by grasping them with a pair of pliers or inserting a tight fitting screwdriver into the hex.
    Works in a pinch.
  9. #9
    Registered user. Jay Fortner's Avatar
    Feb 2011
    Chiefland,Fl.
    4,983
    Default Re: Howard Miller (Hermle 340-020A) Wrench? (By: Scottie-TX)
    Industrial suppliers sell small allen screwdrivers in sets both metric and SAE. I've got one of each and wouldn't part with them for love nor money.
    -> posts merged by system <-
    Quote Originally Posted by Scottie-TX View Post
    Works in a pinch.
    Hey man, I think your latest avatar cat is allergic to himself.
    Gun control is the ability to hit the target.
    http://rosewoodregulators.com/
  10. #10
    Dec 2009
    Louisville, KY
    594
    Blog Entries
    Default Re: Howard Miller (Hermle 340-020A) Wrench? (By: Jay Fortner)
    Thanks Mark for the information.
    1.3mm allen wrench is the right tool.
  11. #11
    Apr 2004
    Mesquite, TX
    938
    Yeah; Self inflicted - cat scratch fever.
  12. #12
    For what it's worth: This same allen wrench is also used and included with a Bergeon reamer adapter for an electric screwdriver, part #22911, Timesavers Catalogue #36, page 111, which I have, AND have lost a time or two much to my chagrin. Good to know you have some Mark. I'll be calling you soon!................doc
    Post Script: It is also used on part #'s 22910 and 22912 in the Timesavers catalogue.
    Exodus 31:6 "...and I have given to all able men ability, that they may make all that I have commanded you."
  13. #13
    Default Re: Howard Miller (Hermle 340-020A) Wrench? (By: doc_fields)
    Quote Originally Posted by doc_fields View Post
    Mine came with a screw Maybe it's been modified recently.
  14. #14
    I know this thread is old but it seemed to fit. I was looking for the hex tool to remove the Chime Locking Plate (cam) on a Howard Miller 341-020A movement. I bought a 1.3 mm hex tool but it is too small. Still looking for the right size. I am assuming it's metric. I will keep trying and post if I can find it. Any additional suggestions are welcome.
  15. #15
    Default Re: Howard Miller (Hermle 340-020A) Wrench? (By: John Rausch)
    1.5 mm works. Also I have a .050" square that fits the moon gear and several other things too.
  1. Hermle 340-020A speed adjustment problem
    By sulliv103 in forum Clock Repair
    Last Post: 09-09-2012, 09:53 AM
  2. Hermle 340-020A slow...
    By joe4227 in forum Clock Repair
    Last Post: 11-01-2009, 12:15 PM
  3. Hermle and Howard Miller the same?
    By shutterbug in forum Clock Repair
    Last Post: 05-28-2008, 12:19 PM
  4. Hermle 340-020A Hairspring Balance out of range
    By bchaps in forum Clock Repair
    Last Post: 06-29-2005, 08:23 AM
  5. Howard Miller 340 020 Movement
    By Dave_P in forum Clocks General.
    Last Post: 01-12-2005, 07:50 AM
