NOTICE Notice: This is an old thread. The last post was 2283 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 6 of 6
    Registered user. Paul Raposo's Avatar
    Nov 2005
    Cambridge, ON Canada
    686
    Default Changing Date On Rolex 1525?
    Hey all.
    Bought a Rolex Air-King-Date, which I believe has the 1525 movement. The date is a slow change, (starts about 9:30PM and finishes around 12:15AM) and is not a quickset. So how do I adjust the date on this?
    Registered User doug sinclair's Avatar
    Aug 2000
    Calgary, Alberta
    14,368
    Blog Entries
    Default Re: Changing Date On Rolex 1525? (By: Paul Raposo)
    There is no quick way to change the date on this model, short of using a cordless drill to do the job (which I do NOT personally recommend). These were made before to era of the "quick-change" calendar on this model, so it's 'round and 'round you go. The "back-and-forth" method used on some watches of the era doesn't work on these either. You may turn the hands backwards or forwards, depending on which direction requires the fewer turns to get to the correct date.
    Nov 2005
    686
    Default Re: Changing Date On Rolex 1525? (By: doug sinclair)
    Quote Originally Posted by doug sinclair View Post
    Now he tells me
    So I can move the hands forward, or backward, like on the 1601 Datejusts?
    Nov 2005
    686
    Thought I'd some pictures.
    -> posts merged by system <-
    Doug, while I have your attention;
    The seller said he had the watch serviced by a local watchmaker, not Rolex. The watch is currently losing 20 seconds per day. Is there any way to tell if the movement has been serviced when the case is opened, or could it just need to be adjusted, or regulation?
    Aug 2000
    Calgary, Alberta
    14,368
    Blog Entries
    If it happens that a 1601 model has a caliber 1535 movement in it, then it has a "quick-change" calendar which changes instantly on the hour. But it still doesn't have a quick re-set. With the caliber 1535 you must move the hands ahead until the calendar changes, STOP, BACK UP to about 9:00, then go ahead until the calendar advances again. On these, the date ring doesn't back up! IIRC, the quick re-set feature didn't appear until the caliber 3035 movement. A rule of thumb that usually works is that the "quick-set", "quick-change" calendar occurred at about the time the sapphire crystal was introduced. In short, reversing the hands on the 1500 series movements will also back up the calendar ring. So it's round and round, forwards or backwards, whichever way is shortest to get to the date you want. As to 20 seconds a day! Assume that it either has NOT been done, or perhaps it has been half done. Assume that many vendors go for the cheapest job they can get, often just enough to get the watch running. I have an Air-King that I have had since 1971, and it runs within 10 seconds per WEEK! But then, I'm the only one who has ever worked on it!
  6. #6
    Nov 2005
    686
    Excellent info, Doug, thanks
    I wore the watch for three days, and when I realized how much it was losing, I set it aside. Guess I'll be saving up for a servicing this summer.
    I'm stealing this comment for future use.
  1. Directions to change day & date on old Bucherer watch
    By Raymond Stuart in forum Wrist Watches
    Last Post: 03-22-2009, 12:19 PM
  2. Electrical Wristwatch Changing dials on a Waltham pocket watch
    By MikeC in forum Watch Repair
    Last Post: 11-16-2005, 03:26 PM
  3. Changing bezel on Rolex GMT
    By RonC in forum Wrist Watches
    Last Post: 10-09-2005, 09:11 AM
  4. Mechanical Wristwatch location of serial number on Rolex oyster datejust
    By 4piet1 in forum Watch Repair
    Last Post: 09-22-2005, 02:55 PM
  5. CROWN ON ROLEX BOMBE' WATCH
    By watch nutt in forum Wrist Watches
    Last Post: 03-11-2003, 06:26 AM
