hello...i have a watch-craft motor...i recently took it apart and cleaned it,changed the brushes,in order to fix a problem that i have been having with it..when it runs it runs fine but just some times it just does not work...i have to play with the forward and reverse switch in order to get it to run and now it only runs in one direction and even for that to happen i have to play with the switch...im assuming that i need to replace the switch...i was wondering if anyone had a similar problem or if they did where would they go to fix it..how much do you think it will cost to replace the switch??id rather not get a new motor but if i did id like to replace it with a more powerful motor but i dont know what kind of motor i currently have so i dont know what would be a step up..thanks for any advise you guys might have
