Goal: $300, Received: $30.00 (10%) Contribute Now
Results 1 to 3 of 3
    Exclamation Clock Construction Forum
    The original "Construction of a Skeleton Clock" forum was put in place to cover the building of one particular clock. Since other clock construction projects have been discussed here as well, it was decided to open up the forum to Clock Construction in general.
    I have volunteered to moderate this forum and hope it will provide a valuable resource to anyone building their own clock or those who just enjoy reading about projects like this. Discussions and questions about clock building problems and sharing of tips and new ideas are also encouraged.
    So let the chips fly and have fun!
    Allan Wolff
    Jul 2011
    cardboard box
    6
    Default Re: Clock Construction Forum (By: Allan Wolff)
    i have a jewelers regulator that has a kieninger 80 cm. drop for pendulum, mvmnt. has a graham dead beat with brass leader. can any one tell me where to measure from end to end to modify lire pendulum so that i'm at 80 cm.
    Hello
    I am looking for plans to build a one month going spring driven mechanism. I don't really need the full plans for the frames and levers, ect but would like the gear train
    plans (number of teeth and sizes of the gears). Does anyone know where I can find some more info on this?
    Darryn Clark
  1. Sourcing Brass for Clock Construction
    By Ed P in forum Clocks General.
    Last Post: 04-12-2009, 03:21 PM
  2. Poll: A new name for "Clock Repair" Forum
    By GoogleKnowsThis in forum Clock Repair
    Last Post: 09-09-2008, 12:36 AM
  3. Another clock-oriented forum
    By bangster in forum Clock Repair
    Last Post: 04-21-2007, 05:02 PM
