Goal: $300, Received: $185.00 (62%) Contribute Now
Results 1 to 9 of 9
    Default How to fix MOP dial ( Mother of Pearl)
    I have a tiny crack line on the MOP watch dial and like to do some Touch-Up to cover the crack. Could someone advise how to do it, perhaps painting, sprayiny or polishing.
    Thank you in advance.
    John
    Default Re: How to fix MOP dial ( Mother of Pearl) (By: jnch88)
    Quote Originally Posted by jnch88 View Post
    John
    I'd recommend either leaving it alone or sending it into a dial refinisher. I have a mother of pearl dial in for refinishing right now. If you want, I'll post the before and after photos when it comes back and you can see how it looks. It should be back within about one week.
    Default Re: How to fix MOP dial ( Mother of Pearl) (By: Dale)
    I'll second Dale's suggestion to leave it alone - any attempts to repair or disguise the crack could render results which may be more distracting than the original flaw.
    The only other options I can suggest would be to have it professionally restored or find a replacement dial.
    Default Re: How to fix MOP dial ( Mother of Pearl) (By: Barb B)
    Quote Originally Posted by Barb B View Post
    Why does MOP crack? How do i prevent it?
    Registered User doug sinclair's Avatar
    Aug 2000
    Calgary, Alberta
    14,368
    Blog Entries
    Default Re: How to fix MOP dial ( Mother of Pearl) (By: newbieccwan)
    The layer of mother of pearl is brittle, and most often, very thin. If the layer is not well glued to the substrate, there will likely be voids in the glue which leave the MOP unsupported. Even removing the hands with hand removers can crack the MOP. Ask me how I found THAT out!
  6. #6
    Default Re: How to fix MOP dial ( Mother of Pearl) (By: doug sinclair)
    Quote Originally Posted by doug sinclair View Post
    Thanks Doug. I did a bit of research and it appears that MOP is a hydrated gemstone. I would assume one would then moisten and finish with an oil or some sort to stop the evaporation. However, I like your take on it with the glue; logically it does seem correct that poor 'glue-support' might lead to cracks.
    Any other ideas?
  7. #7
    I know this is a very old topic but I'm needing to understand the same thing about a crack in MOP dial. I don't see where anyone post a "before & after" photo of a dial sent off for repair/refinishing. I'm hoping the photo is someplace that I can access for reference. The pearl dial belongs to me and I'm hoping to make the repair in house? I was thinking of using my G-S HYPO Cement to glue the 2 pieces together?
  8. #8
    Default Re: How to fix MOP dial ( Mother of Pearl) (By: jimtone)
    I'd use super glue, it dries a white-ish color and can blend in surprisingly well. That's what I use when repairing MOP scales on pocket knives.
  9. #9
    Aug 2000
    Calgary, Alberta
    14,368
    Blog Entries
    Default Re: How to fix MOP dial ( Mother of Pearl) (By: NC Plumber)
    Hiding of minimizing the appearance of a crack in a mother of pearl dial effectively is not possible. Perhaps a dial refinisher might be able to replace the layer of mother of pearl might be possible.
  1. How to Fix Wheel Out of True
    By proconsul in forum Clock Repair
    Last Post: 07-10-2004, 10:39 PM
  2. MOTHER OF PEARL TO RESTORE INLAID CLOCK
    By P Gorman in forum Clock Case Restoration and Repair.
    Last Post: 04-22-2003, 02:05 AM
  3. How to fix Loose Dial paint?
    By Robert Ling in forum Reverse Glass and Dial Painting.
    Last Post: 04-04-2003, 12:30 PM
  4. How to fix Loose Dial paint?
    By Robert Ling in forum Clocks General.
  5. How to fix Loose Dial paint?
    By Robert Ling in forum Clock Case Restoration and Repair.
