Goal: $300, Received: $370.00 (124%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2249 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 3 of 3
    Default Centurion 35 Day
    Hello I bought this Clock at a Yardsale Im into pocketwatch more than clocks but anyway. I was wondering First where can I get parts ofr this? Also Can someone tell me about it? It looks as if the Mainspring is broke I dont know if it is It didnt come with a key. there is a Metal bar at the bottom of the case I see where it goes do I just put it back in? For the experts looking at this what do you think of the clock and what do you think it might run to repair it. If I buy the parts or should I just take it to a clock repair shop Thanks Tim
    Attached Thumbnails Attached Thumbnails IMG_8829.jpg   IMG_8830.jpg   IMG_8831.jpg   IMG_8832.jpg   IMG_8833.jpg
    Nov 2002
    39,219
    Default Re: Centurion 35 Day (By: Timothy Davis)
    Hi, Tim. Your clock is Korean. Valuewise, it probably isn't worth spendng much money on it. Timesavers can supply you with a mainspring if it is indeed broken. It was probably made within the last 30-40 years, if not newer than that. These clocks can be made to run well, and the movements are at least on par with modern German movements for reliability. They just are not prized by any serious collectors.
    The metal bar is a chime rod, and it will need a bit of work to re-attach it. Also I don't see a pendulum in your pictures.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Registered user. Peter's Avatar
    Jan 2010
    Bethlehem, Rural NW CT
    188
    Metal bar looks like it came out of the strike sounding block on the right bottom. You are also missing the pendulum. I can't identify it but it looks fairly modern.
    -Pete
    -> posts merged by system <-
    This is the second time within a week that Harold and I have posted almost simultaneous replies with similar information. I guess that this furthur reinforces the adage that great minds think alike. I appreciate being in such lofty company.
    -Pete
  1. 35 Day chimes at 10 past the hour
    By Ken M in forum Clock Repair
    Last Post: 04-25-2009, 08:46 AM
  2. Help identifying a 8 day wood works movement
    By Jim Burghart in forum Clocks General.
    Last Post: 01-22-2007, 11:19 AM
  3. 400 Day Suspension Assembly Fixture
    By MrEthan in forum Horological Tools
    Last Post: 03-01-2006, 05:38 AM
  4. Korean clock Commodore 35 days
    By pichon in forum Clock Repair
    Last Post: 01-08-2006, 06:08 AM
  5. 400 day clock runs slow
    By dantheman in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 05-14-2001, 01:21 AM
