Goal amount for this month: 300 USD, Received: 230.00 USD (77%) Contribute Now
Donate whatever you can or Join the 16,000 other NAWCC members for only $72 (plus $10 for hard copy publications). Check it out here.
NOTICE Notice: This is an old thread. The last post was 460 days ago. If your post is not directly related to this discussion please consider making a new thread.
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 33
  1. #16
    Registered User leeinv66's Avatar
    Mar 2005
    Launceston Tasmania
    3,395
    Blog Entries
    Default Re: Kundo electro-mechanical clock help needed
    Quote Originally Posted by Tinker Dwight View Post
    It seems that the movement from the quartz clock could
    have been made to drive the coil in the original with very
    little work.
    I would guess the original and the quartz one were quite
    similar.
    You could be right Tinker, I had the same thought. But, being far from competent with electronics, I went with the parts I already knew worked.
    Cheers
    Peter: AKA (Pee-Tah) from Australia
  2. #17
    Registered user.
    Dec 2003
    West Yorkshire, England
    9,813
    Peter
    So, you're using the quartz to actually drive the coil? I'm interested. Shame you're on the opposite side of my planet!
    Dwight
    I've only heard of those meters but never seen them here; I have a military spec Avo 8 that I got as a prezzie when I left my first job in 1967 to move up north, and as it's been calibrated a few times, trust it implicitly. Lead reversal is my usual transistor test method. There's another Avo 8 that lives in the workshop outside, plus about five cheap £5 digitals that actually have a transistor/diode test function.
    If I need to go as far as hfE testing, I have a Taylor instrument from the 1950's when transistors cost a small fortune then.
    Apologies to moderators for wandering a bit O/T, but electronics is becoming nearer and nearer to horology; the former was my working life, the latter my hobby.
    Mike - banned member of the throwaway society.
  3. #18
    Registered user.
    Oct 2010
    4,143
    Hi
    I believe the quartz had a separate circuit to swing
    a pendulum that is independant from the quartz time keeping.
    It is just to make the pendulum effect.
    I've not traced one down but think it is similar to the
    original Kundo.
    Next time I see one with the pendulum, at a garage sale,
    I'll have to rip one apart and see if it makes a good drive
    for one of these clocks. I don't see why it wouldn't.
  4. #19
    Nov 2002
    28,994
    Tinker, Timesavers sells a unit that just swings a pendulum, meant to wrap around your typical square quartz movement. Takes a separate AA battery. Part # 23552.
    Not sure how it would keep in sync with a Kundo pendulum, but maybe it doesn't matter.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
  5. #20
    Registered user.
    Oct 2010
    4,143
    Hi Harold
    It looks like it works on the same principle.
    There is a magnet on the end of the hanger
    and a coil in the base.
    I would think it is basically the same.
    Dwight
  6. #21
    Registered User Scottie-TX's Avatar
    Apr 2004
    Mesquite, TX
    8,973
    Kudos Pee-Tah!
    They're similar to KUNDOS.
    I'da never thunk ta do that. Congrats!
  7. #22
    Registered user.
    Nov 2010
    harrison ohio near cincinnati
    wow I like that I think you are on to something here not sure if this will work on my lantern as the coil and movement are mounted on clear plexiglass.
    I think i have one of those quartz movements around here somewhere.I might give this a try...............thanks tom
  8. #23
    Registered user.
    Nov 2010
    hello mike did I understand correct that the original tf65 transistors are avalable in your country? if so are they costly and could you help us out over here ?
    I like peter's idea and I will try it if all else fails............thanks TOM
  9. #24
    You have it reversed...N is the "cathode", and P is the "anode".
    To forward bias a PNP base-emitter junction, the negative lead goes to the BASE lead, and the positive lead goes to the EMITTER lead. A transistor must be forward biased to turn on.
    Something else you need to remember...and it is bloody important!...the current through a semiconductor junction MUST BE LIMITED!!!
    The coils have enough DC resistance to limit the current through the transistor junctions to a safe value, but if you connect the battery voltage DIRECTLY across the transistor junctions, it will blow them out! As an example: if the (-) terminal of the 1.5 volt battery is connected directly to the base lead of a PNP transistor (whether silicon OR germanium) AND if the (+) terminal of the same 1.5 volt battery is connected directly to the emitter lead, the transistor is toast!!! In electronics tech lingo, this is called "excessive forward bias", and the result is called a "catastropic failure".
    Most digital multimeters have a "diode" function built in. This may be used to safely test the transistor junctions.
  10. #25
    Using the circuit from a quartz clock to drive the coils is an interesting thought- but a quartz clock ticks at a one-second rate, and I though I read somewhere that these Kundo clock tick at a THREE-SECOND rate?
    These two frequencies are incompatible.
  11. #26
    Nov 2002
    28,994
    Yeah, I figured that may be a problem, considering on these pendulum drivers, it doesn't matter what the beat per minute is, as the pendulum is only for decoration. However, since all that is needed is a pulse to maintain pendulum oscillation, I do wonder if one of these might be able to be tuned in somehow to the beat needed for a Kundo? Would an extra, unneeded two pulses be a problem, as long as there is a pulse there when needed? Anyone tried this since last summer?
  12. #27
    And I might add...stay away from using the Rx1 or Rx10 scales on the multimeter. These scales will very likely allow too much current to flow through the transistor junction(s), causing damage to the transistor. Use the Rx100 scale.
  13. #28
    ...well, it's about time! (snucker-snucker-snucker!)
  14. #29
    [QUOTE=harold bain;636378]Yeah, I figured that may be a problem, considering on these pendulum drivers, it doesn't matter what the beat per minute is, as the pendulum is only for decoration. QUOTE]
    ? That's news to ME- I thought the pendulum rate was what ran the clock...
    Even so, if you input a one cycle per second pulse into the pendulum coil, the pendulum has to swing at a one second rate, or it can't keep up with the input pulses.
  15. #30
    AW...you've got KITTY!
  1. Electro mechanical (Ever Ready) clock identification ?
    By Graham in forum Electric Horology
    Last Post: 03-27-2013, 07:43 PM
  2. Kundo electro - mechanical clock running too fast
    By dennishoy in forum Electric Horology
    Last Post: 05-07-2012, 03:59 PM
  3. Bar electro-mechanical clock
    By collin in forum Clock Repair
    Last Post: 12-29-2006, 09:40 AM
  4. Hamburg American clock help needed
    By Lisa in forum Clocks General.
    Last Post: 03-29-2004, 09:35 AM
  5. Electro-Mechanical Clocks
    By gre406 in forum Clocks General.
    Last Post: 12-22-2002, 11:26 AM
