NOTICE Notice: This is an old thread. The last post was 2237 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 3 of 3
    Registered User MCCLINTOCK-LOOMIS's Avatar
    Jun 2009
    poulsbo wa
    198
    Default McClintock loomis master clock stained glass dials
    Hello,I have a couple of O.B.McClintock Loomis master clocks both suffering from ugly dial syndrome so I decided to make stained glass replacements patterned from an original dial design. I will be needing to make a few larger dials 26" and 32" for a couple of outside clocks in the future along with the upper panels so I figured these would be a good warm up projects for practice. I was very pleased with the end result and thought I would post them. next I'm looking forward to cleaning the movements to add some sparkle behind the dials.
    George
    Attached Thumbnails Attached Thumbnails IMG_2261.jpg   IMG_2264.jpg   IMG_2271.jpg   IMG_0003.jpg   IMG_2077.jpg
    Nov 2002
    39,095
    Default Re: McClintock loomis master clock stained glass dials (By: MCCLINTOCK-LOOMIS)
    Looks great, George. I don't see very many (actually none) McLintock Loomis clocks up here.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Jun 2009
    poulsbo wa
    198
    Default Re: McClintock loomis master clock stained glass dials (By: harold bain)
    Thanks Harold,Their around down here if you look long enough.
    George
  1. McClintock Master Clock - diagrams needed
    By skruft in forum Clocks General.
    Last Post: 10-08-2011, 06:44 AM
  2. McClintock-Loomis clocks
    By Joe Gensheimer in forum Clocks General.
    Last Post: 07-07-2010, 11:46 AM
  3. Here's my Telechron Type E vacuum glass master clock
    By M. Frank in forum Your Newest Clock Acquisition
    Last Post: 12-21-2009, 08:50 PM
  4. Dial for SET 60 beat master clock
    By neighmond in forum Electric Horology
    Last Post: 05-02-2009, 08:18 AM
  5. Broken glass dial for Hammond 15in walll clock
    By ticktocktony in forum Electric Horology
    Last Post: 04-23-2008, 02:44 PM
