Goal: $300, Received: $370.00 (124%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2268 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 6 of 6
    Registered User etmb61's Avatar
    Oct 2010
    Mascoutah
    1,403
    Default Kundo 9" suspension
    Hi,
    Should this lower block pin be loose fit, or should I have to drive it out? This one is very tight, and from the looks I though it would be held in place by the cupped washer and spring. Or am I wrong...
    Also, this clock should take a .0023" wire right?
    Thanks, Eric
    Default Re: Kundo 9" suspension (By: etmb61)
    The part you reference (I think I see what you mean) is part of the pendulum. The block goes into it, and is held by the spring. On rare occasions, I've had to drive out the block pin to remove it.
    Registered User Burkhard Rasch's Avatar
    Jun 2007
    Twistringen
    3,925
    Default Re: Kundo 9" suspension (By: shutterbug)
    The lower block goes into the slot as usual,without the pin.The transverse pin to go through the block has to be snug fit and has to be cut to length,as the spring loaded cup-ring goes over it from above and holds it in place.The original pins have a hump in the middle that sometimes fits verry strongly in the lower block´s apperture and is not easily removed.It´s a double safety device,like belt and suspenders .All in all a bit fumbly to remove and to reinstall,but verry safe!HTH
    Burkhard
    Gigni de nihilo nihil,et nihil in nihilum posse reverti
    (Persius)
    Oct 2010
    Mascoutah
    1,403
    Default Re: Kundo 9" suspension (By: Burkhard Rasch)
    Quote Originally Posted by Burkhard Rasch View Post
    All in all a bit fumbly to remove and to reinstall...
    To say the least, I had some other words for it!
    Eric
    Registered user.
    Feb 2009
    Holiday, FL
    800
    Ah yes! The old pin-in-the-collar trick! Fond memories. I learned the hard way how exactly that pin has to fit in the collar, that was a battle!
  6. #6
    Registered user. NECCnut's Avatar
    Dec 2009
    Greater Rockford area
    464
    Yes, .0023" spring should be right. I have a clock very similar to yours and also serviced and sold one and they both took that size spring.
    And yes, very much a pain with those friction pins, but proper tools and learning and patience and it isn't too hard.
    Quote Originally Posted by etmb61 View Post
    Hi,
    Thanks, Eric
    Steve Fierz
    sdfstudios.com
  1. Suspension springs, Kundo impulse clocks
    By DC Kelley in forum Electric Horology
    Last Post: 04-05-2006, 04:43 AM
  2. Kundo Quartz Anniversary Clock Suspension Spring Unit
    By Joe Collins in forum Clocks General.
    Last Post: 07-09-2005, 11:51 PM
  3. Kundo - broken suspension spring
    By joe228sam in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 04-21-2004, 08:17 PM
  4. How to chose a Kundo suspension spring
    By Lincolnhill in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 11-18-2002, 02:25 AM
  5. Kundo suspension spring
    By rfiam in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 08-25-2001, 04:34 AM
