Notice: This is an old thread. The last post was 916 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 9 of 9
Thread: Brewster & Ingrahams Drop Length
12-16-2010, 04:01 PM #1Registered User
- Join Date
- Jul 2010
- Posts
- 4
I have a Brewster & Ingrahams 8 day movement--its the earlier flat plate type and not one with the raised rib--it was the type that B&I's made after having made the Kirke type movement--the escapement bridge comes from the right side of the front plate. The movement is out of a steeple clock and it has 46 teeth on the escapement wheel--the verge embraces 9 teeth. Here's the problem--I cannot get the movement to run slow enough--I've lowered the suspension to the bottom of the case and it still runs a few minutes fast every hour. What could the problem be--how can I get it to run slower?
12-16-2010, 04:30 PM #2
Re: Brewster & Ingrahams Drop Length
Hi, Daniel, and welcome to the message board. Tran's Ingraham book shows a few different movements for their steeple clocks. Are you sure yours is original? You might be able to weight the bob at the bottom to change the center of gravity, or use a longer crutch.
harold bain, Member ch 33
"If it won't "tick",
let me "tock" to it"
12-16-2010, 05:58 PM #3
I have a B&I steeple whose movement wants to run fast, though not so fast as yours. I'm able to get good time keeping with the bob nearly at the bottom of the hanger. Have you checked whether the EW is skipping due to wrong depthing or a short tooth or two?
12-17-2010, 12:34 AM #4Registered User
- Join Date
- Jul 2010
- Posts
- 4
I have the movement out of the case and have run it in a movement stand. Both the escapement wheel and the verge appear to be original. All the teeth on the escapement are fine and the verge engages them all correctly. I believe that the bob is correct as well--its a bigger one and I have the suspension spring as long as I can make it--with the bob at the bottom of its hanger.
-> posts merged by system <-
I have several Brewster and Ingrahams clocks--including some with the same movement--although none are the just a regular steeple clock--one is a beehive, one is a 4 post beehive, a 4 post steeple. Does the crutch wire effect its speed? The loop end of the crutch on this movement only comes to the bottom of the front plate's horizontal section. Does how many teeth the verge embraces change the speed of the movement?
12-17-2010, 01:40 AM #5
My experience has been that crutch length has little affect on operation - especially regulation. Others will disagree. One can reckon that a shorter crutch will need more power to push the pendulum the same no. of degrees from a higher position and conversely. But we're not facing a power problem here.
The number of teeth embraced by the pallet span will not change regulation. Few will disagree. At this point I'd shoot for bottom weighting the bob if that is possible.
12-17-2010, 08:35 AM #6
Daniel, since you have the same movement in other clocks, you can compare the pendulum length and the crutch length in these clocks to the problem one. The number of teeth the anchor spans won't have any affect on regulation, as there is only one tooth released at a time. The crutch length does affect regulation to some extent, but not likely enough to account for a few minutes every hour. The longer the crutch, the further the pendulum has to swing to work the escapement, which slows the clock. Also provides more power to the pendulum, giving a longer swing. A short pendulum swing will make a clock run faster.
12-17-2010, 08:38 AM #7
Hi,
How about changing the thickness of the suspension spring(feather)?A thicker one even by .001 will have a noticeable affect.
tom
12-17-2010, 11:07 AM #8Registered User
- Join Date
- Mar 2003
- Location
- Los Angeles
- Posts
- 430
Is this a time & strike movement or time only. I know that it is sometime possible to accidentally swap wheels from the strike train to the time train. There is a later Gilbert movement where the 2nd wheels "look" exactly the same and I swapped them once. When I put it on the test stand it ran great, but gained about 2 to 3 minutes an hour.
12-17-2010, 11:16 AM #9
By Steven Thornberry in forum Clocks General.Replies: 5Last Post: 03-26-2010, 04:59 AM -
Pendulum Drop Length
By superfine_7d04f4 in forum Clock RepairReplies: 18Last Post: 12-04-2009, 12:22 PM -
Brewster? (and Ingraham??) spring brass clock.
By timeandagain in forum Clocks General.Replies: 16Last Post: 12-01-2008, 01:38 AM -
Ingraham Drop Octagon
By Wayne C. Anderson in forum Clocks General.Replies: 3Last Post: 11-12-2008, 09:24 PM -
Weight Drop Length
By jkey in forum Clocks General.Replies: 4Last Post: 06-16-2004, 07:27 AM
About the Message Board
This will be an ongoing blog to chronicle the development and use of the NAWCC Message Board. Please reply with your thoughts as you feel appropriate. June 2013 marks the deployment of the last edition of vBulletin V4. We will continue using this version of the software until vBulletin V5 has been widely deployed and had a thorough shakedown. That may take as much as 3 years. In order to freshen the look of the message board, several changes have been made in this deployment. The most...
05-31-2013, 04:23 PM in Tom McIntyre
