Goal: $300, Received: $115.00 (38%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2401 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 4 of 4
    Default Dating Chauncey Boardman
    Hello,
    I purchased a steeple Chauncey Boardman with a double fusee. The research on the clock based on the Chauncey Boardman label was 1810 to 1832. In 1833 a partnership was formed and then the labels were Boardman & Wells. I removed the works and the plate is stamped C Boardman with a patent date of 1847. What is the accurate date?
    Thanks,
    Default Re: Dating Chauncey Boardman (By: rfh11)
    Looking through Spittlers and Bailey, I note that Wells left the partnership in 1844. In 1847, both Boardman and Wells received a patent for a reversed fusee mechanism. It would be good to see pictures of case, label, and movement to let our experts have the best shot at providing information.
    Here is a link to the patent on Google Patents.
    “If one tells the truth, one is sure, sooner or later, to be found out.” - Oscar Wilde
    Thanks for the information. Based on the patent application I can only assume that Boardman used labels that he previously printed. I would do the same. I will look closer at the label to see a printers mark is evident.
    Thanks again
    Chauncey Boardman was one of Bristol, CT's early makers, with a career spanning the decades from wood works to brass. In fact, he is generally credited with developing the "groaner movement".
    The dates for the firm of Boardman and Wells (Chauncey Boardman and Joseph Allen Wells), based upon tax records, is 1832-43. However, some sort of ongoing production and connection existed between them until 1848 when Wells went bankrupt. It's all very confusing to me.
    On 1/1/4/1847, Boardman and Wells were granted patent number 4914 for a method of attaching fusees to movements originally designed to be driven by weights. These movements are often found in steeple cases, as well as other types. The labels may say "Chauncey Boardman" and occasionally "C. Boardman, also by J.A. Wells".
    For lots more info, see Roberts and Taylor, Forestville Clockmakers, pages 5-33 with the figures therein. There are nice examples of steeples with their fusee movements and labels illustrated. Frankly, I fined it a tough read, as there is endless minutia about land transactions, mortgages, etc. But the information is there.
    Also see the American fusee clock thread, in particular:
    http://mb.nawcc.org/showthread.php?t=59464&page=2
    At the top of that page, there's a great Boardman triple fusee steeple posted.
    Please post pics of the clock, movement, and label, too.
    RM
  1. Chauncey Boardman WW clock
    By harold bain in forum Wood Movement Clocks
    Last Post: 04-04-2011, 06:00 PM
  2. Replies: 23
    Last Post: 01-19-2010, 05:43 PM
  3. Chauncey Boardman Transition Clock Label
    By mlschlot in forum Clock Case Restoration and Repair.
    Last Post: 12-22-2009, 07:03 PM
  4. seeking date & information on watch
    By terry hall in forum American Pocket Watches
    Last Post: 01-21-2004, 09:58 AM
  5. addition to my posting dated 11-20-2001 16:24
    By darngoodpick in forum American Pocket Watches
    Last Post: 11-22-2001, 06:50 AM
