Goal: $300, Received: $250.00 (84%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2321 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 3 of 3
Thread: Schatz question
    Default Schatz question
    When did Jahresuhrenfabrik begin calling itself Aug. Schatz und Sohn? When did they start using the Schatz logo on the front of their cuckoo clocks?
    (Yes, I'm trying to get a very rough date for a cuckoo clock.)
    bangster
    Moderator leeinv66's Avatar
    Mar 2005
    Launceston Tasmania
    7,325
    Blog Entries
    Default Re: Schatz question (RE: bangster)
    Bangster, I think the company August Schatz und Sohn was registered back in 1881, so that won't help date your cuckoo. However, I think the familiar "Schatz" logo started to be used sometime around the late 1940s early 1950s.
    Cheers
    Peter R Lee: AKA (Pee-Tah) from Australia
    Default Re: Schatz question (RE: leeinv66)
    Greetings Bangster --
    This is one of those "normally messy" areas in that the firm that we treasure today as Schatz went through several names since it was founded in (according to the Lexikon) 1880. To make it more interesting, there's the question of when a certain tradename was registered as compared with when it was actually used in a certain style on clocks.
    That mumbled, it would appear that what was known after 1897 as the Jahresuhrenfabrik-Triberg GmbH became the Jahresuhren-Fabrik GmbH August Schatz & SŲhne in the early 1920s. One indication is a trademark registration from 1921 (below).
    As far as the Schatz goes, there's a registration from 1923 (also below). Don't notice as it just makes it messier the name given to the firm. Perhaps they were just saving space...? When a particular style of the mark was first used is a different question.
    Regards
    Zep
    Attached Thumbnails Attached Thumbnails Schatz TM 1921.JPG   Schatz TM 1923.jpg
  1. Schatz cuckoo starwheel question
    By bangster in forum Clock Repair
    Last Post: 08-22-2006, 06:28 AM
  2. Another Schatz cuckoo question.
    Last Post: 08-01-2006, 07:31 AM
  3. Schatz cuckoo question
    Last Post: 07-24-2006, 09:31 AM
  4. Schatz 53 rotation question?
    By Jeff C in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 02-01-2006, 08:53 AM
  5. Schatz 1000 day Model 54 Questions
    By Billtcat in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 03-14-2005, 03:26 AM
