Notice: This is an old thread. The last post was 4037 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 3 of 3
Thread: What is the best way...
05-30-2002, 03:07 AM #1fecit^imGuest
to remove a balance staff?
Any preferred method? How do u go about it to avoid deforming the wheel and how to straighten it when it occurs...pointers please.
05-30-2002, 03:07 AM #2fecit^imGuest
05-30-2002, 05:59 AM #3MikePGuest
Riveted staff or friction staff? If a friction staff, a staking tool is used with the appropriate stakes. A riveted staff should be removed by turning off the "head" portion in the lathe. There is also a special tool for use with a staking set that many people use to remove a riveted staff without turning it off on the lathe. It works pretty well but is not as "safe" a method as turning off the rivet - it can still distort the balance under some conditions.
"The Watch Repairer's Manual" by Henry Fried covers all staff-related operations in great detail, including straightening balances, etc. I highly recommend the book. Short of quoting the many pages (and pictures) verbatim, I can think of no way to explain it properly on a site like this. But perhaps others here who are better with words and explanations could properly do so...
What is the best way to clean a painted base?
By fille in forum 400-Day, Atmos and other Torsion ClocksReplies: 4Last Post: 10-16-2006, 06:44 AM -
What is the best way to store the pocket watches?
By usadude in forum American Pocket WatchesReplies: 24Last Post: 09-21-2006, 10:50 AM -
What is the best way to remove a pressed on pinion?
By Dave Schwartz in forum Clock RepairReplies: 15Last Post: 07-04-2006, 04:59 PM -
What is the best way to see all those tiny ladies ww parts, as you work?
By Kate N in forum Watch RepairReplies: 11Last Post: 07-30-2005, 03:59 AM -
What is the best way to remove rust?
By nelsonek in forum Watch RepairReplies: 9Last Post: 05-31-2004, 12:18 PM
About the Message Board
This will be an ongoing blog to chronicle the development and use of the NAWCC Message Board. Please reply with your thoughts as you feel appropriate. June 2013 marks the deployment of the last edition of vBulletin V4. We will continue using this version of the software until vBulletin V5 has been widely deployed and had a thorough shakedown. That may take as much as 3 years. In order to freshen the look of the message board, several changes have been made in this deployment. The most...
05-31-2013, 04:23 PM in Tom McIntyre
