Goal: $300, Received: $325.00 (109%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2431 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 8 of 8
    Apr 2002
    19,722
    Blog Entries
    Default Solder in a tube.
    Has anyone tried this product, if you have did you like it?
    [ame="http://www.amazon.com/Permatex-25906-Liquid-Solder-1-5/dp/B000HBM2ZI"]Amazon.com: Permatex 25906 Liquid Solder - 1.5 oz.: Automotive[/ame]
    Default Re: Solder in a tube. (By: Kevin W.)
    Quote Originally Posted by Veritas View Post
    I tried it once a long time ago to reattach a dial pan to the bezel. It didn't work well at all for that application It might do better as a filler when a hole needs to be retapped or to fill in a low area .... something like that. Haven't tried it.
    Default Re: Solder in a tube. (By: shutterbug)
    Hello!
    I had the same experience as Shut. I didn't find it very practical in clock repair work.
    Thanks!
    Neal
    Registered User Scottie-TX's Avatar
    Apr 2004
    Mesquite, TX
    938
    Default Re: Solder in a tube. (By: ticktock19852004)
    Solder is solder. This is not. Probably a plastic filler with metallic mixture.
    Default Re: Solder in a tube. (By: Scottie-TX)
    Vinyl resin adhesive. Contains no metal. No stronger than any other vinyl glue.
    You want something that works, use JB Weld.
    Sez me,
    bangster
  6. #6
    Registered user. al_taka's Avatar
    Feb 2006
    Maspeth, Queens NY
    1,040
    Default Re: Solder in a tube. (By: bangster)
    Scottie,
    It doesn't conduct at all, just silver colored. i can't think of a use for it.
    Veritas,
    Do you have a specific need for a glue, or just want to see whats out there for future repairs?
    One of the strongest and amazing glues I've come across is Red Locktite for locking new pivots.
  7. #7
    Apr 2004
    Mesquite, TX
    938
    Default Re: Solder in a tube. (By: al_taka)
    I'm not a long time user of it - only learned of it's qualities here - but suspect Loctite may be the very best glue for metal to metal. I'm a HUGE fan of cyanoacrylites but it fails miserably on low porosity materials like glass, steel, etc. For a solder bond there's NO good substitute for real solder.
  8. #8
    Hello!
    I use Loctite as well. It has never failed. I use it for pivots; and when replacing trundles.
    Thanks!
    Neal
  1. Help hanging chime tubes in a grandfather clock
    By darticus in forum Clock Repair
    Last Post: 07-31-2012, 09:08 AM
  2. Chime-tubes in a gf clock: what do they hang from?
    By Spaceman Spiff in forum Clocks General.
    Last Post: 06-29-2011, 10:43 PM
  3. Repair a crack in a Tube Chime????
    By trevor thomas in forum Clock Repair
    Last Post: 11-23-2005, 12:41 AM
  4. Crown superglued in the tube!
    By bchaps in forum Watch Repair
    Last Post: 09-11-2005, 05:22 AM
  5. Swiss Pocket Watch Watch Runs Three Seconds In Stem-Out Position
    By IJ in forum Watch Repair
    Last Post: 09-18-2004, 11:12 PM
