Goal: $300, Received: $350.00 (117%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 3899 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 8 of 8
Thread: Replating Brass
    J.S.H.
    Guest
    Default Replating Brass
    Can anyone tell me how to replate brass and what equipment might be needed? I have some cherubs and other ornaments off an old Gibert I would like to restore. Thanks!
    J.S.H.
    Guest
    Default Replating Brass (By: J.S.H.)
    Registered user. Mike Phelan's Avatar
    Dec 2003
    West Yorkshire, England
    9,823
    JSH
    I would try to use some of these wax type polishes - cannot give you product names in US.
    They deposit a mixture of metal dust and wax, and can be buffed up.
    I am not sure at all how brass can be plated, as it is an alloy, but am sure that it has been done.
    Mike - banned member of the throwaway society. :o
    Hello J.S.H.,
    A Brass is typically not plated on any object; it was used for marine clock cases. A silvery nickel finish is often plated on brass and other metals.
    Brass is a composite made from Copper & Zinc; its color and hardness depends upon their ratio. Sometimes a small amount of lead is added to the mixture.
    Andy
    Registered User inbeat's Avatar
    Nov 2000
    Phoenix, AZ
    1,846
    If you are talking about cherubs like on a mirror side clock, they are most likely pot metal and not brass....they can be colored by rub n buff...a commercial product that is a wax like Mike talked about. Pot metal can be plated brass or nickel.
  6. #6
    You might try Caswell Platings Plug n Plate Kits. I have not used one myself so cannot speak to how well they work.
  7. #7
    J.S.H.
    Guest
    Thank you for your help everyone. I apologize for not replying sooner.
  8. #8
    Brass is rather difficult to plate because it's really two quite different metals- copper and zinc- which have to be deposited simultaneously in the right proportions. If it's going on steel or pot metal, the base needs to be carefully prepared (pickled in acid) to remove oxides, then it has to be pre-plated with another metal, such as copper, often twice. Current densities, pH, salt concentrations, and temperature need to be carefuly controlled. Brass plating was not commercially developed until mid-20thC, and used highly poisonous cyanide solutions. Most commercial platers shun it.
  1. Brass replating
    By bud4u2 in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 06-14-2010, 05:22 PM
  2. Replating Brass
    By J.S.H. in forum Clock Repair
    Last Post: 08-20-2006, 03:13 PM
  3. How do you restore the brass looking base?
    By shutterbug in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 06-04-2006, 04:52 PM
  4. Cable Material: Bronze or Brass
    By Sid Daniels in forum Clock Repair
    Last Post: 09-25-2005, 10:56 PM
  5. Which brass alloy?
    By R. R. Cross in forum Clock Repair
    Last Post: 09-11-2003, 03:28 PM
Members who have read this thread: 1
