Goal: $300, Received: $360.00 (120%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2530 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 8 of 8
    Registered user. mikeald's Avatar
    Mar 2010
    Wales, United Kingdom
    526
    Default mainspring grease
    Hi guys,
    I have access to many different types of grease in work. And I was wondering what type would be suitable for lubricating a mainspring?
    (If any)?
    At the moment I am using the proper clock grease, but is there an equivalent I can use? If so, which type of grease would be best?
    Cheers
    Mike
    Registered user.
    Jun 2009
    Central Florida
    874
    Default Re: mainspring grease (By: mikeald)
    Hi Mike,
    I would continue using the correct clock grease, as they are designed for that application. I wouldn't substitute the correct grease for others that I had at work.
    Samantha
    Nov 2002
    39,208
    Default Re: mainspring grease (By: Samantha)
    Mike, this recent thread might be a good read for you regarding mainspring lubrication:
    http://mb.nawcc.org/showthread.php?t=62431
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Mar 2010
    526
    Default Re: mainspring grease (By: harold bain)
    Thanks for the replies
    Well in the UK, I do not think I can get hold of slick 50, therefore Samantha I will indeed be sticking with clock grease
    Thank you
    Mike
    Registered user. Lynne Gillette's Avatar
    Aug 2008
    In a Tudor Cottage named Squirrelton
    81
    Actually, very few lubricants are actually developed for clocks! Most of your mainspring greases are from other industries. Transmission fluids, brake fluids, bearing greases, etc. One was not even developed as a grease! It's original intent was vacuum formed plastic products!
    This is why arguments about clock lubricants are so amusing!
    A loving wife, a treasured friend, and a dream proved a broken man could be repaired.
  6. #6
    Mar 2010
    526
    Default Re: mainspring grease (By: Lynne Gillette)
    Well I have access to at least 30 different types of grease, all with different chemical properties.
    I might experiment......
    Mike
  7. #7
    Nov 2002
    39,208
    I think the main concern with mainspring grease/lubricant is that it needs to retain its characteristics over a long period of time, without degrading or becoming sticky. Short term success isn't as important as long term success.
  8. #8
    Hi MIke,
    You can get slick 50 from Halfords or most motor accesory shops.
    I use the synthetic slick 50 mixed with high pressure oil to lubricate
    mainsprings.
    Where abouts are you in Wales. I live in a little place called Llandovery.
    Best wishes
    Edward
  1. Grease for mainsprings
    By kologha in forum Clock Repair
    Last Post: 01-08-2012, 12:03 PM
  2. Mainspring Grease Recommendation
    By bajaddict in forum Clock Repair
    Last Post: 03-22-2011, 07:49 AM
  3. Watch oils and Mainspring Grease
    By Quinton Bradford in forum Watch Repair
    Last Post: 08-21-2008, 10:14 AM
  4. How to apply grease/oil to mainspring
    By time2keep in forum Clock Repair
    Last Post: 05-27-2008, 07:52 PM
  5. mainspring grease...how much
    By chrsvor25 in forum Clock Repair
    Last Post: 09-21-2007, 10:49 PM
