NOTICE Notice: This is an old thread. The last post was 2485 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 4 of 4
Thread: Elgin 290
    Default Elgin 290
    I recently acquired an Elgin 290 pocketwatch from 1920. The watch is in working order and the seller informed me that it had recently been serviced. However, I cannot figure out how to set the time. The winding stem doesn't pull out and I removed the bezel to find that it doesn't have a lever. I was hoping someone could help me.
    Apr 2002
    19,722
    Blog Entries
    Default Re: Elgin 290 (RE: phibbitts)
    Did you get in touch to talk to the seller about your setting problem.I know a Grade 291 is pendant set, but not sure about the 290.
    Default Re: Elgin 290 (RE: Kevin W.)
    I have and the seller was a antique jewerlry trader and says he didn't recall every actually setting the watch. What is pendant set, I'm unfamiliar with that method?
    Jul 2009
    Kentucky
    2,694
    As per the sales catalog, it should be pendant set. This means that you pull the crown out to set the time.
    Sometimes, the sleeve is "tight" and it takes quite a bit of force to pull out. It can help to turn the crown just a little bit while trying to pull.
  1. The 12s Elgin "mustache" lever
    By Beetlebug in forum American Pocket Watches
    Last Post: 02-02-2016, 09:08 PM
  2. Replacing a Sleeve in a JBoss HC Cased 16S 290 Elgin
    By BTraicoff in forum American Pocket Watches
    Last Post: 03-04-2006, 12:55 PM
  3. Anyone Remember This Lord Elgin Diamond Bezel Watch?
    By Andy in Boca in forum Wrist Watches
    Last Post: 01-05-2006, 05:50 AM
  4. Elgin G.M. Wheeler Question
    By java1214 in forum American Pocket Watches
    Last Post: 05-25-2005, 10:44 AM
  5. Electrical Wristwatch seeking San Diego area repair person (elgin pocket watch)
    By doug sinclair in forum Watch Repair
    Last Post: 11-28-2003, 03:36 AM
