Goal: $300, Received: $300.00 (100%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2386 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 7 of 7
    Mar 2009
    South Bend, IN
    Default Deytime Register time clock
    Has anyone more information on the Deytime Register time clock? The dial has Endicott, N.Y. written as to their location. This is a large time clock with a ticker tape inside to record start and stop times with employees. The front of the clock has a large moveable arm to record the person, looks like up to 149 employees, that they move the arm with a pin into and it records the time they "clocked in".
    Thanks in advance
    Jim
    Nov 2002
    38,869
    Default Re: Deytime Register time clock (RE: ccpjim)
    Hi, Jim. This site has a pretty good history of Dey clocks:
    http://www.antiquetimeclocks.com/events.html
    I suspect yours was made after ITR purchased Dey, just from the Endicott location.
    The home page may also have some information of interest to you:
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Mar 2009
    South Bend, IN
    Default Re: Deytime Register time clock (RE: harold bain)
    Thanks Harold! I sent an email off to antique time clocks after seeing that they are looking for some of these clocks.
    Appreciate it very much.
    Jim
    Nov 2002
    38,869
    Jim, I found a bit more on Dey in the book, "An Empire in Time" by Oechsle and Boyce.
    Dey Time Register Company was sold to ITR in 1907, and moved to Enticott, NY. ITR retained the Dey Time Register clocks as one of their line of clocks, and the dial recorders were made and serviced by ITR as late as 1950.
    Registered user.
    Aug 2010
    penn valley,ca
    Injoyed reading your post----sounds like you have a wealth of knowledge. Just acquired a Dey Time Register and need the two wheels and lever that was supposed be mounted on the front. Thanks for any help, Charles Crow Penn Valley, Ca chasdi@att.net
  6. #6
    Nov 2002
    38,869
    Default Re: Deytime Register time clock (RE: chasdi)
    Hi, Chasdi, welcome to the message board. It will take a lot of luck for you to happen onto your missing parts. I have an ITR dial clock that is also missing it's front wheel and punch mechanism.
    Post a few pictures of yours.
  7. #7
    Registered user.
    Aug 2010
    penn valley,ca
    Hi Herold, thanks for the reply. I also have a ITR (cut-off),the case that they put the movement in is nice and it keeps good time. It will go 3 weeks between windings. I found a web site that has the wheels and lever--to the tune of $1000. My clock is not in that price range, so I can't justify that kind of money . Take Care, Charles Crow Penn Valley, Ca
    -> posts merged by system <-
    Harold---sorry for spelling your name wrong. Now you know in the spelling bee's who was one of the first ones to sit down. Chas
  1. International Time Clock Register
    By Joel Zautner in forum Clock Repair
    Last Post: 08-24-2010, 07:17 PM
  2. Time Clock Mainsprings
    By Tom Englund in forum Clock Repair
    Last Post: 09-28-2006, 03:36 AM
  3. Replies: 3
    Last Post: 07-17-2006, 10:40 AM
  4. Single Fusee 'World Time' clock 1856
    By JTD in forum Clocks General.
    Last Post: 11-15-2005, 12:45 AM
  5. Advertising Simplex Time Clock needing case?
    By harold bain in forum Clocks General.
    Last Post: 04-30-2005, 01:02 PM
