NOTICE Notice: This is an old thread. The last post was 2544 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 3 of 3
    Dec 2008
    South Carolina
    32
    Default Swihart Rocking logo Coca Cola clock
    I have a SWIHART PRODUCTS ELWOOD INDIANA rocking logo Coca Cola neon clock. The mechanism that links the motor to the logo is missing. Does anyone have any information or a picture of this?? A picture of the neon transformer would also be appreciated.
    Thanks in advance.
    Feb 2005
    Wi
    156
    Default Re: Swihart Rocking logo Coca Cola clock (By: gentleman jim)
    Check the sticky on the repair forum for Wayne's neon clock supply,by far the most available parts for neon clocks
    Registered user. Ingulphus's Avatar
    May 2006
    Oakland, CA
    702
    Default Re: Swihart Rocking logo Coca Cola clock (By: analogtime)
    The size and type of transformer will depend on the width and length of the neon tubing, as well as if it's neon or argon/mercury. There are a couple of other companies that sell transformers (I've used Tech-22 and West Coast Custom Designs), and each will list the maximum width and length for each gas that a particular transformer will power, as well as the dimension, to ensure it will fit inside the case.
    Avoid over-powering the neon; an electronic transformer has the advantage of self-adjusting to the load while a "core and coil" does not. And, of course, ensure that the case is properly grounded.
  1. vintage coca cola wall clock
    By plove53 in forum Clock Repair
    Last Post: 09-27-2011, 05:06 PM
  2. Sessions Coca Cola Clock
    By Travis in forum Clocks General.
    Last Post: 06-15-2009, 02:24 PM
  3. Coca-Cola Fishtail Electric Clock Restoration HELP
    By john foote in forum Clock Repair
    Last Post: 04-02-2004, 03:54 AM
  4. Repair of PAM electric movement for Coca-Cola clock
    Last Post: 03-10-2004, 05:14 AM
  5. Coca-Cola clock 1952
    By john foote in forum Clocks General.
    Last Post: 02-24-2004, 11:55 PM
