NOTICE Notice: This is an old thread. The last post was 2645 days ago. If your post is not directly related to this discussion please consider making a new thread.
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    Registered User Jeff C's Avatar
    May 2005
    Seven Fields, Pennsylvania
    2,119
    Default #4/0 Emery paper
    Would anyone know where I can buy some #4/0 Emery paper? I prefer to make my own buff sticks to use, I'd like to find just the paper.
    Thanks,
    Apr 2002
    20,011
    Blog Entries
    Default Re: #4/0 Emery paper (By: Jeff C)
    Jan 2007
    Maryland
    472
    Default Re: #4/0 Emery paper (By: Kevin W.)
    Jeff: You might look at this one as well. Paul
    http://shorinternational.com/Emery.htm
    May 2005
    2,119
    Default Re: #4/0 Emery paper (By: Paul Arsenault)
    Thanks guys, appreciate the quick replies. Looks like Shore Intl has the Fine #4/0 I'm looking for. If anyone wants to know I use this material for the final buff on clock pivots.
    Nov 2002
    39,369
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
  6. #6
    May 2005
    2,119
    Default Re: #4/0 Emery paper (By: harold bain)
    Quote Originally Posted by harold bain View Post
    Thanks Harold. They have a nice selection but it seems all their telephone numbers are disconnected. Too bad I liked their stock.
  7. #7
    Nov 2002
    39,369
    I guess maybe another victim of the economy, Jeff.:o
  8. #8
    Registered User Neeth's Avatar
    May 2007
    El Dorado, CA
    208
    Maybe I'm just looking on the negative side -- but maybe there are fewer and fewer craftsmen left, those of us that care enough to do it right, to keep our favorite suppliers in business.
    Neeth (Ken)
  9. #9
    Apr 2002
    20,011
    Blog Entries
    Default Re: #4/0 Emery paper (By: Neeth)
    Yes ken there are perhaps fewer people but many reasons why businesses shut down.
  10. #10
    Apr 2004
    Mesquite, TX
    938
    Forgive my dumbness please, but what is #4/0 emery? Is this paper with the abrasive quality of 0000 steel wool?
  11. #11
    Registered User Jim DuBois's Avatar
    Jun 2008
    Magnolia, TX
    Default Re: #4/0 Emery paper (By: Scottie-TX)
    Scottie,
    WetOrDry Abrasive Sheet - #4/0 (2000 Grit)
  12. #12
    May 2005
    2,119
    Quote Originally Posted by Scottie-TX View Post
    No pun intended Scottie but its the "cats meow" for finishing pivots. at least for me
    If I were to guess 0000 steel wool would be 1000-1500 grit. #4/0 emery paper is 2000 grit. This is my guess from buying the two from time to time.
  13. #13
    Apr 2004
    Mesquite, TX
    938
    Indeed it is the cat's "me - OW!". I use 2500 made by 3M.
    I just never read of an abrasive paper thus described.
    Interesting tho - 0000? I believe it may be less abrasive than 2500 as when polishing brass, it removes scratches left by 2500, prior to polishing. Simichrome then removes scratches left by 0000, so it may be around 6000 or higher.
  14. #14
    Registered user. cazboy's Avatar
    Apr 2006
    Prescott Valley, Arizona
    1,109
    Default Re: #4/0 Emery paper (By: Jim DuBois)
    Quote Originally Posted by Jim DuBois View Post
    Scottie,
    Wow - I was just going to ask the same thing. Thanks, Jim.
    What grit is crocus cloth? Along with my emery paper assortment I bought some crocus cloth, which I use for my FINAL FINAL treatment on clock pivots. It just feels like paper, though. Hard to believe it's actually abrasive.
    Does it have a grit number?
    Doug Haeussler, NAWCC #0167553 - Prescott Valley, AZ
  15. #15
    May 2005
    2,119
    Default Re: #4/0 Emery paper (By: cazboy)
    One thing I have noticed. I bought some 3M 2000 grit yesterday and compared it to one of the buff sticks I bought from R&M which were "fine" #4/0 and it was a little smoother than the 3M 2000 grit.
  1. Paper dial replacement
    By Seth Thomas Fan in forum Clock Case Restoration and Repair.
    Last Post: 06-12-2006, 09:53 AM
  2. Paper Clock??
    By bangster in forum Clock Repair
    Last Post: 05-25-2006, 05:32 PM
  3. Clock Paper Overlay
    By Dick Bailey in forum Clocks General.
    Last Post: 02-25-2006, 11:43 AM
  4. Cuckoo Papers
    Last Post: 01-30-2006, 05:20 PM
  5. Resoring Paper Labels
    By Sooth in forum Clock Repair
    Last Post: 02-21-2005, 10:25 PM
