NOTICE Notice: This is an old thread. The last post was 2733 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 13 of 13
    Default ID-Nice Wall Clock???
    Attaching a picture of a nice looking wall clck. Any idea on make or model. Kind of looks new.
    Advice or info appreciated, thanks.
ID:	50397   Click image for larger version.
ID:	50398   Click image for larger version.
    Popeye-Love This Forum!!!
    Apr 2002
    20,077
    Blog Entries
    Default Re: ID-Nice Wall Clock??? (By: popeye)
    Nice looking clock Popeye.Looks new to me, perhaps the case was stripped and refinished.Would be nice to see whats behind the dial, i dont know what the maker is.
    Mar 2006
    White Plains, NY
    71
    Default Re: ID-Nice Wall Clock??? (By: Kevin W.)
    Hi Popeye,
    Your clock looks to me to be a Korean reproduction of the Waterbury "Leeds" model. These clocks were manufactured and sold sometime in the 1970's or 80's by a company called Korusa. I believe Merritts also sold them.
    Stan
    Feb 2007
    Avoca, Iowa-USA
    84
    Hi Popeye. looks like the Waterbury Leeds. The top finial looks a bit different then the one pictured in Tran's book, Waterbury Clocks And Watches . From 1893, came in oak, walnut, and cherry, 8 day time or 8 day with half hour strike, is 40 and 1/4 inches tall with 8 inch dial.
    Denny
    Oops, could be repo as Stan sugested.
    Apr 2002
    20,077
    Blog Entries
    Default Re: ID-Nice Wall Clock??? (By: DennyI)
    The dial and the pendulum dont have that Korean look to me.
  6. #6
    Feb 2007
    Avoca, Iowa-USA
    84
    Hard to tell by the picture but the gong kind of has that reproduction look.
    Denny
  7. #7
    I can not take the dial off. Any thing to look for to see if repo? Thanks for all the replies.
  8. #8
    Nov 2002
    39,629
    By the looks of the wire hanging down from the movement, it has a countwheel, something you won't find on a Korean clock. But the case looks too good to be very old. Look at the screws on the hinges. If they are Phillips or Robertson screws, it is newer.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
  9. #9
    Feb 2007
    Avoca, Iowa-USA
    84
    The nut on the center shaft could be questionable as well. looks like a nut that is holding the munute hand on where most Waterbury movements were configured with a tapered pin through the center shaft. Are there any labels on the case?
    Denny
  10. #10
    More pics if these help:
ID:	50406   Click image for larger version.
ID:	50407   Click image for larger version.
  11. #11
    Nov 2002
    39,629
    Sure looks like a Leeds, but way too new looking. The gong (what I can see of it) doesn't look right either.
  12. #12
    Default Re: ID-Nice Wall Clock??? (By: harold bain)
    The springs look somewhat narrow from what little I can see. I think it would have had a cathedral gong as shown below. The photo is from a 2008 auction by R. O. Schmitt.
    The wooden dial surround in popeye's picture isn't correct either. The clock also looks somewhat "short" although that could be the photo. Should be just over 40 inches (40 1/4" h).
    Best,
    Richard T.
  13. #13
    Registered user. Robert Ling's Avatar
    Apr 2002
    SoCal.
    1,072
    Default Re: ID-Nice Wall Clock??? (By: Richard T.)
    In the picture looking up to the movement, it looks like the mask or skirt around the dial wasn't finished on it's bottom edge ?
    If so, I think an original would have been.
  1. Help Needed to ID a wall clock
    By ClockFanatic in forum Clocks General.
    Last Post: 02-29-2012, 03:41 PM
  2. Help me ID this Wall Clock PLEASEEE!
    By czendejas in forum Clocks General.
    Last Post: 12-17-2010, 11:34 AM
  3. Help in Id'g wall clock date and maker....
    By NJMZ in forum Clocks General.
    Last Post: 01-16-2010, 08:39 PM
  4. Help Please With ID of Wall Clock
    By dholk in forum Clocks General.
    Last Post: 10-21-2009, 06:22 PM
  5. Help ID German wall clock trademark and age
    By Frank Menez in forum Clocks General.
    Last Post: 05-26-2005, 11:07 AM
