Goal: $300, Received: $30.00 (10%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2782 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 2 of 2
    Cool S and F pendulum adjustements
    In an anniversary clock with rotating pendulum, if the clock is Fast do I turn the correction pendulum adjustment toward F??
    Registered User Burkhard Rasch's Avatar
    Jun 2007
    Twistringen
    3,990
    Default Re: S and F pendulum adjustements (By: FredWJensen)
    No,Fred,You allways turn the knurled nut in the direction of the desired correction,that is:If the clock is desired to run slower,turn the nut in the direction of S,if it´s supposed to run faster,turn it to F.HTH
    Burkhard
    Gigni de nihilo nihil,et nihil in nihilum posse reverti
    (Persius)
  1. Replies: 6
    Last Post: 08-10-2008, 02:47 PM
  2. Suspension spring & pendulum adjustment
    By skclock in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 12-23-2007, 06:24 AM
  3. Seth Thomas Globe and general pendulum Qs
    By anniemac in forum Clock Repair
    Last Post: 03-24-2007, 07:34 PM
  4. Replies: 12
    Last Post: 08-15-2006, 11:32 AM
  5. BOOKREVIEW: Stevenson: German Patents and Torsion Pendulum Clocks
    By Fortunat Mueller-Maerki in forum Horological Books
    Last Post: 08-31-2002, 03:44 AM
