Notice: This is an old thread. The last post was 1290 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 4 of 4
Thread: Spring size for ST 124
12-07-2009, 11:45 AM #1Registered user.
- Join Date
- Aug 2004
- Posts
- 700
What is the size of the spring on the chime side of a Seth Thomas 124 in length, width, and thickness?
thanks
tick
12-07-2009, 12:07 PM #2
Re: Spring size for ST 124
.75" X .018" X about 60" should work. You may have to get the 96" one and shorten it.
Of course, this assumes that the one on my bench is original
12-07-2009, 08:01 PM #3
Factory chime train spring was 3/4" X .016" X 78" or 19mm X .43 X 1982, 3/4" X .017" X 72" which is more common works fine, runs eight days easily. Best - CW
12-07-2009, 09:21 PM #4Registered User
- Join Date
- Nov 2009
- Location
- NORTHWEST WASHINGTON
- Posts
- 102
Trans duy ly lists the chime spring for a 124 at 3/4" wide x .015"thk x 72" long
page 968 third edition volume 2,u can order almost the exact relacement from timesavers,i think the thickness is .016" that they offer,check their catalogue
-> posts merged by system <-
3/4" wide x .015" thk x 72" long
Need help with unusual chime pattern for ST 124.
By blueloon in forum Clock RepairReplies: 27Last Post: 05-21-2010, 12:42 PM -
What cable size for ST #2?
By RLM in forum Clock RepairReplies: 8Last Post: 06-23-2008, 08:48 AM -
ST 124 Chime Spring Problem
By dholk in forum Clock RepairReplies: 2Last Post: 09-20-2007, 09:21 AM -
Need new spring in ST #124 mvt
By Chris in forum Clock RepairReplies: 2Last Post: 02-22-2007, 08:03 PM -
bob for the ST 124 movement
By vincent in forum Clocks General.Replies: 1Last Post: 11-23-2006, 11:56 PM
About the Message Board
This will be an ongoing blog to chronicle the development and use of the NAWCC Message Board. Please reply with your thoughts as you feel appropriate. June 2013 marks the deployment of the last edition of vBulletin V4. We will continue using this version of the software until vBulletin V5 has been widely deployed and had a thorough shakedown. That may take as much as 3 years. In order to freshen the look of the message board, several changes have been made in this deployment. The most...
05-31-2013, 04:23 PM in Tom McIntyre
