NOTICE Notice: This is an old thread. The last post was 2730 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 10 of 10
    Jan 2009
    New Jersey
    223
    Default Identifying Clock Movement
    My mom received this clock from a friend in Holland many years ago. The clock unfortunately was dropped many years ago and the ceramic was glued back together. My mom gave me this clock but it was not working very well. I uninstalled the movement from this case and oiled the clock movement but did not oil the hair spring platform. I used Slick 50 one lube for the mainspring. The spring was accessible to lube so I did not dissemble this movement since I am not familiar on how to service a hair spring yet. The movement is running now after I oiled the pivots and lubed the mainspring but does need to be cleaned especially the hair spring. How do I service this type of hair spring?
    This clock case and movement has no information that I can find identifying this clock/movement. I did notice some symbols on the back of the movement which may provide some hint. Does anyone know who made this clock? I have attached pictures for your review.
    Attached Thumbnails Attached Thumbnails ClockRay1.jpg   ClockRay2.jpg   ClockRay3.jpg
    Default Re: Identifying Clock Movement (By: dalesr)
    Hello,
    There appears to be a logo stamped on one plate.... If you could get a clear photograph of the logo, some message board member might have a European Tradename book and help identify the movement maker.
    Andy
    Default Re: Identifying Clock Movement (By: Andy Dervan)
    Blink blink...stare and compare. With a little enlarging and color editing, the logo appears clearly as one used by Japy Freres.
    H.J. (Les) Lesovsky, Alhambra California
    Jan 2009
    New Jersey
    223
    Default Re: Identifying Clock Movement (By: eskmill)
    Eckmill thank you so much for identifying this movement. Japy Freres is a 19th Century Clock Maker so this clock was made in the 19th Century, right?
    Is this a quality movement?
    I am also interested in finding a replacement for the case since it was broken and glued back together. Were there many of these clocks made with this case and what do I search for on Ebay to find one?
    Eckmill thanks again for identifying this movement.
    Ray
    Registered Users
    Sep 2008
    Irish, but live in Laprade, 16390, France, (70 miles east of Bordeaux)
    3,240
    Ray,
    Your clock is one of these (pic). The cases on these are (real) porcelain. I would carefully repair the glue joins and keep it as it is.
    Just in case I am wrong about the "porcelain",(the case may have been changed) shine a bright light through it and you should be able to see the light and a shadow of your fingers or whatever.
  6. #6
    Jan 2009
    New Jersey
    223
    Default Re: Identifying Clock Movement (By: laprade)
    Laprade,
    My father or mother glued this porcelain case. I will try shining a light through it per your instructions below. I will keep it like it is.
    Thanks much for identifying the case.
  7. #7
    Registered Users
    Sep 2008
    3,240
    I forgot to mention that Japy were making clocks well into the 20th c as well. I posted two alarums in the "french markets" thread the other day, and have seen quite modern models with their logo. "Japy"
  8. #8
    Jan 2009
    New Jersey
    223
    Laprade,
    I appreciate the follow-up on this since I was wondering if "Japy" clocks were made in the 20 century as well. I would imagine that my mother's clock was made in the 20th century.
    Ray
  9. #9
    Jan 2009
    New Jersey
    223
    Laprade,
    I did the light test and this is a porcelain clock case.
    Thank you for providing me this information.
    -Ray
  10. #10
    Registered Users
    Sep 2008
    3,240
    dalesr,
    Glad to be of help.
    stephen
  1. Please HELP identify clock movement
    By mbegalla in forum Clocks General.
    Last Post: 10-24-2010, 05:46 PM
  2. Help to identify a Mappin & car clock movement
    By pdaneu in forum American Pocket Watches
    Last Post: 02-22-2007, 06:41 AM
  3. How to identify an American vs English Grandfather clock movement
    By Weight Driven in forum Clocks General.
    Last Post: 10-28-2006, 05:55 PM
  4. identify maker of 30 hour cottage clock movement
    By uncletom in forum Clocks General.
    Last Post: 02-23-2006, 04:13 PM
  5. help in identifying clock movement
    By steve.wrigley in forum Clocks General.
    Last Post: 08-19-2003, 11:17 PM
