American Clocks Vol 3 by Spittler & Bailey
Langdon & Jones Burlington Conn Circa 1835
Watchmakers & Clockmakers of the World Vol 2 by Loomes
William Langdon & George A. Jones Bristol USA 1845-55
I know very little of this company and have found not much when Goggled.
I have a case with the label on it that saysImproved clocks, Langdon and Jones on it.Its in rough shape but all there.It needs a lot of work to get it to be a decent looking clock.I saw one on the internet and it is a 8 day with a wooden movement.Any ideas what this one had and how it looked? Does anyone have clocks made by this maker?
I took these pictures with my new camera.It is a Sony DSC-W180
Great Label on the case Kevin. That case should keep you busy for a little while
Good luck!
Grant
Kevin,
You clock had triangular columns like my Daniel Pratt clock. I can probably measure the angle for you (might just be a 45 degree but I'm not sure). Also, because it's a solid door with the columns attached, I'd suggest putting a mirror in it. These are the original "looking glass" style clocks.
The movement looks like it would have been a traditional style wooden works, but attached with screws (the movement would have had 4 pre-drilled screw mounting holes in the backplate for this). So no side rails. I do have a movement that is back-mounted like this that I could photograph for you.
The splat would have been either stencilled (normally) or mahogany veneered (more likey since your clock did not have stencilled columns).
Thanks everyone for the information it will be helpful.
Yes Sooth could you give the angle of those pieces that go on the front.
I think the hardest part will be to find a movement and dial for this clock.I was thinking i might have to go with a 30 hour ogee movement.
I saw another clock on the internet made by this maker and it had feet on it.
Veritas,
I just picked up a Langdon and Jones at auction today. Its complete, a little time worn, but will look nice once cleaned up. I will post a couple picks in a day or so if your still interested.
Billy
Hi Billy i would like to see pictures of your clock, it would be of help.Thanks.
Veritas,
Here are some pics, if you need more or different angle, let me know.
What little research I can find, I'm guessing that the weights are not original. The splat has been replaced. The bottom glass, eh? who knows. Probably replaced.
I don't have pics of the movement, its in pieces. Its really in pretty good shape. Some teeth have been replaced. But it had a funky spotty lookin white mold? growin on it. So, I just finished a dunk and swish in bleach/soap mix.
BTW, How does one determine if you have an 8 hr. or 30 hr. movement?
Billy
Hi Billy, if the weights came with this movement, and they weigh about 3 pounds each then its a 30 hour, if they weigh about 8 pounds then a 8 day clock.
I would like to see pics of the movement when you can get to it, thanks and great pictures.Looks like a nice one to restore.
I got a langdon and jones clock that works
I got one in an auction
