NOTICE Notice: This is an old thread. The last post was 2813 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 8 of 8
    Registered user. tittualex's Avatar
    Oct 2009
    Trivandrum, Kerala, India
    33
    Default Mauthe Clock Movement
    dear Kevin,
    last evening i bought an old chiming movement.... unfortunately the case was not there.....
    it is MAUTHE.
    it has the following numbers written on the movement.
    W500
    1665570
    can i find out the age from this/?
    thanks ,
    Alex
    Default Re: Mauthe Clock Movement (By: tittualex)
    Alex: I'me separating this from your thread on Kienzle. Again, pictures might be helpful.
    “If one tells the truth, one is sure, sooner or later, to be found out.” - Oscar Wilde
    Nov 2002
    39,742
    Default Re: Mauthe Clock Movement (By: Steven Thornberry)
    Alex, as far as I know there is no database to date Mauthe clocks by serial numbers.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Oct 2009
    33
    Default Re: Mauthe Clock Movement (By: harold bain)
    thanks ....... i will post pictures..........
    Oct 2009
    33
    Dear all,
    I have attached the pictures of my Mauthe movement. hope this will help in finding the age of the clock.
    regards,
    Alex.
ID:	46463   Click image for larger version.
ID:	46464   Click image for larger version.
ID:	46466   Click image for larger version.
    Attached Images Attached Images
  6. #6
    I'd say around 1930's to 1940's. Not too often you find a post 1930 Mauthe wall clock.
    "A good gong sells the clock!" - Justin A. Olson
  7. #7
    Apr 2002
    20,106
    Blog Entries
    Default Re: Mauthe Clock Movement (By: chimeclockfan)
    I am with Chimeclock on approximate age of this clock.
  8. #8
    Default Re: Mauthe Clock Movement (By: Kevin W.)
    I Just worked on one of these movements in Jan
Name:	F. Mauthe 002.jpg
ID:	46469   Click image for larger version.
Name:	F. Mauthe 003.jpg
ID:	46470   Click image for larger version.
Name:	F. Mauthe.jpg
  1. Mauthe Grandfather Clock movement
    By Rlundqui in forum Clock Repair
    Last Post: 02-23-2015, 07:26 AM
  2. Cuckoo clock movement question
    By mckpaul in forum Clock Repair
    Last Post: 03-25-2012, 09:51 PM
  3. popularity of Quartz Grandfather clock movements?
    By 107WestStreet in forum Clocks General.
    Last Post: 05-17-2006, 04:00 AM
  4. Hermle granfather clock movement chimes won't function
    By 107WestStreet in forum Clock Repair
    Last Post: 02-25-2006, 05:24 PM
  5. Building an American Clock Movement
    By George in forum Clock Repair
    Last Post: 02-26-2005, 12:57 PM
