Goal: $300, Received: $335.00 (112%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 2722 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 3 of 3
    Apr 2009
    Wake Forest, NC
    Default Sessions Electric Clock Motor
    Have a Sessions elec motor the wires are not accesible. Any suggestions on how to rewire clock. Thanks, Rick
    Apr 2009
    Wake Forest, NC
    Default Re: Sessions Electric Clock Motor (By: Rick1505)
    does anybody know where i can find one of these motors at or a used one thanks rick the wires are gone from this one
    Rick1505.
    At the very least a photo of your damaged Sessions clock motor is needed.
    The Sessions electric clock motors went through an evolutionary period and finally settled on a very reliable and inexpensively made unit motor assembly with the field winding deeply imbedded in the field pole assembly.
    The motor assembly is found with various schemes for securing the motor assembly to the clock gear train, the simplest a three "knob" twist-into-place mount used on lots of United and Master Crafters novelty clocks among others.
    I cannot imagine a practical way to remove and replace the field winding in the most common Sessions clock motor. The motor field assembly manufacturing method is not ameniable to disassembly. It is put together on a punch press
    I'd suggest searching for a donor motor from a discarded clock having an identical mounting method.
    H.J. (Les) Lesovsky, Alhambra California
  1. Need Sessions electric clock motor advice
    By ggordon in forum Electric Horology
    Last Post: 01-23-2009, 05:40 PM
  2. Help with a Session electric clock motor??
    By DML Clocks in forum Electric Horology
    Last Post: 12-19-2008, 01:49 PM
  3. Sessions Electric Clock Motor...Help!
    By TxnTravlr in forum Electric Horology
    Last Post: 10-31-2006, 03:46 PM
  4. Seth Thomas Electric Clock Motor
    By Tom Kloss in forum Electric Horology
    Last Post: 11-16-2005, 06:54 AM
  5. Sessions Electric Clock motor Poor Torque
    By Greg R. in forum Electric Horology
    Last Post: 01-03-2004, 12:51 PM
